Author Topic: C++ help  (Read 1613 times)
C++ help
« on: February 04, 2004, 10:10:16 pm »
I know this is kinda out there, but if any of you know C++ maybe you can help me.
I am taking a class on C++ and I've been working on a simple program.  You input 3 different intergers, and the program has to calculate and display the sum, product, average.  That's the really easy part.
The last part is that you have to have the program display shich interger is the largest, and which is the smallest.
This is how I coded this program.
// Problem 1.26
#include <iostream>
#include <cmath>
using namespace std;
void main()
   int x1, x2, x3, sum, ave, pro;
   cout << "Input three different integers:\n";
   cin >> x1 >> x2 >> x3;
   sum = x1 + x2 + x3;
   cout << "Sum is " << sum << endl;
   ave = sum / 3;
   cout << "Average is " << ave << endl;
   pro = x1 * x2 * x3;
   cout << "Product is " << pro << endl;
   if ( x1 > x2 && x1 > x3 )
      cout << x1 << " is the largest.\n";
   if ( x2 > x1 && x2 > x3 )
      cout << x2 << " is the largest.\n";
   if ( x3 > x1 && x3 > x2 )
      cout << x3 << " is the largest.\n";
   if ( x1 < x2 && x1 < x3 )
      cout << x1 << " is the smallest.\n";
   if ( x2 < x1 && x2 < x3 )
      cout << x2 << " is the smallest.\n";
   if ( x3 < x1 && x3 < x2 )
      cout << x3 << " is the smallest.\n";
My question is, is there an easier way to have it determine and display which integer is largest/smallest?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:C++ help
« Reply #1 on: February 04, 2004, 10:28:02 pm »
You aren't into arrays yet, I take it?
Assuming you aren't, this is more of a math problem than a programming problem :)  If you were into arrays I'd just throught he values in an array and do a bubble sort.
There's many ways to do this.
1 way
Code: [Select]
int min, max = 0;
if (x1<x2)
   if(x1<x3)
      min = x1;
      if(x2<x3)
         max = x3;
      else
         max = x2;
   else
      min = x3;
      max = x2;
else   //x2, x1
   if(x2<x3)
      min = x2;
      if(x1<x3)
         max = x3;
      else
         max = x1;
   else
      min = x3;
      max = x1;
//printout min and max
Another way it to assume and prove wrong
Code: [Select]
min = x1;
max = x3;
if(x2<x1)
   min = x2;
   if(x3<x2)
      min = x3;
else if (x3<x1)
   min = x3;
if(x2>x3)
   max = x2;
   if(x1>x2)
      max = x1;
else if(x1>x3)
   max = x1;
//print max and min
I think this is correct.
« Last Edit: February 04, 2004, 10:32:00 pm by SirPoonga »
Re:C++ help
« Reply #2 on: February 04, 2004, 10:53:09 pm »
No, haven't gotten to arrays, yet.  :)  Just started the class a few weeks ago.  "Computer Programming for Engineers."
Thanks for the help, I'll try your code and see what happens.  From what I can see here, it looks good.  :)
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
Re:C++ help
« Reply #3 on: February 04, 2004, 10:59:56 pm »
Oh!!! An Engineer! ::)
That explains a lot.  ;D
Just kidding! :D
American Laser Games Wrapper
O2em Rom Utility
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
Re:C++ help
« Reply #4 on: February 05, 2004, 09:32:27 am »
Here's another solution using an array with a linear serach
// Problem 1.26
#include <iostream>
#include <cmath>
void main()
   int x[3], sum, ave, pro;
   int highnum,lownum; // high and low numbers
   cin >> x [ 0 ]  >> x[1] >> x[2];
   sum = x [ 0 ] + x[1] + x[2];
   ave = sum / 3;
   pro = x [ 0 ] * x[1] * x[2];
   highnum = x [ 0 ] ;
   lownum = x [ 0 ] ;
   for (int c=0;c<3;c++){
      if (x[ c ]  > highnum){
          highnum = x[ c ];
      if (x[ c ] < lownum){
          lownum = x[ c ];
      cout << highnum << " is the largest.\n";
      cout << lownum << " is the smallest.\n";
« Last Edit: February 05, 2004, 09:33:53 am by PacManFan »
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
Buddabing
Re:C++ help
« Reply #5 on: February 05, 2004, 11:31:42 am »
// Problem 1.26
#include <iostream>
#include <cmath>
void main()
Please read the wiki!
Re:C++ help
« Reply #6 on: February 05, 2004, 04:11:28 pm »
Thanks everyone, for the help... :)
That was a good suggestion, Buddabing, thnx...
Back to coding...
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
Re:C++ help
« Reply #7 on: February 05, 2004, 06:58:30 pm »
ahhh, i remember those q's from when i first took C++. man, my teacher made me comment everything, even a prog like that....
It's all about the Pentiums
Re:C++ help
« Reply #8 on: February 05, 2004, 09:11:48 pm »
Fortunately, my prof doesn't make us comment everything... :)  he just wants a few comment lines at the top naming the program and giving a short description of what it does.
