Author Topic: Xtension arcade emulator trackball - diagonal not working Golden tee  (Read 2438 times)
Topfox124
  • Last login:June 19, 2018, 01:21:33 pm
All,
Trying to play golden tee, all versions have the same issue, and it doesn’t seem to recognize top right to bottom left diagnol on the trackball. Top left to bottom right diagonal works without issue however. Anyone every had a problem like this?  Is there some sort of calibration for the trackball itself?
« Last Edit: June 17, 2018, 02:49:52 pm by Topfox124 »
paigeoliver
  • Awesome face!
Re: Xtension arcade emulator trackball - diagonal not working Golden tee
« Reply #1 on: June 17, 2018, 11:13:20 pm »
is your control panel at an angle?
Topfox124
« Reply #2 on: June 19, 2018, 01:21:33 pm »
Looks like the issue was just happening with GT. Someone suggested deleting the Gt cfg flies and that seems to have fixed the issue for now.
Ajstratmann
  • Last login:August 22, 2018, 09:59:59 pm
« Reply #3 on: August 22, 2018, 10:00:54 pm »
I seem to be having this same issue...can you possibly give me some additional information on how you fixed it.  It’s like for me left right doesn’t work and there is a bit of a drag from when I motion forward and the golfer responds.
