Author Topic: Problems with Ikegami monitor  (Read 3382 times)
Yardley
  • Last login:July 22, 2025, 11:36:15 pm
« on: June 12, 2018, 10:10:05 pm »
Just picked up a nice Ikegami CRT monitor recently and I am having a problem with it that I don't have with my Sony PVM. Basically the only way I get a stable image is when I have my LCD monitor connected to the HDMI port of the video card along with the Ikegami on the VGA port. If I disconnect the LCD monitor, the Ikegami seems to lose sync, although I am not sure it is actually sync that is being lost, point is the picture becomes unstable. Below is a video of what happens when the LCD monitor is unplugged. Once I plug it back into the HDMI port, the Ikegami becomes stable instantly. Any thoughts? I am using csync through CRT EmuDriver by the way.
buttersoft
  • Last login:Yesterday at 07:06:11 pm
  • Is running at 15kHz
Re: Problems with Ikegami monitor
« Reply #1 on: June 13, 2018, 09:55:04 pm »
Ikegami's are known to be sensitive to sync in ways a lot of other monitors aren't. There are sync regenerators you can look into, and also a thread on the shmups forum by samiam about his problems with one. AFAIK there's no simple fix, though you could always try combining sync for yourself.
Yardley
« Reply #2 on: June 13, 2018, 09:58:30 pm »
Disabling AMD External Events Utility fixed the problem! All synced up now without the need to ha e a second monitor plugged in to the hdmi port.
buttersoft
« Reply #3 on: June 14, 2018, 12:27:59 am »
Nice, glad that sorted it.
