Author Topic: Groovymame won't run with numscreens 2  (Read 3841 times)
Vincefaro
  • Last login:July 17, 2025, 11:40:56 am
« on: June 01, 2018, 12:43:36 pm »
I am of course trying to get two monitors to work while running GM .179 . GM works fine with numscreens 1 selected, but when I try to switch to 2, it crashes. Any ideas?
Win 7
I5
16 GB Ram
HS / Launchbox Frontend
D9800 monitor
LCD marquee Monitor
Calamity
  • Moderator
  • Last login:July 19, 2026, 05:56:58 am
  • Quote me with care
Re: Groovymame won't run with numscreens 2
« Reply #1 on: June 02, 2018, 06:16:13 am »
You posted 2 files but no proper useful log.
Anyway, there was a bug preventing multimonitor to work on older versions. Check the "what's new" in the main thread, and update accordingly. Remind only d3d9ex builds will work.
Steps to create a log:
Vincefaro
« Reply #2 on: June 04, 2018, 03:03:41 pm »
oops sorry, I will get you the correct log.
Vincefaro
« Reply #3 on: June 05, 2018, 10:13:13 am »
typed this in a shell   mame64.exe -v dkong >dkong.txt
got this
Unable to create the Direct3D device (8876086C)
unable to initialize Direct 3D 9
Fatal error: Unable to complete window creation
Calamity
  • Moderator
« Reply #4 on: June 05, 2018, 10:58:50 am »
Yeah, that's the old bug I mentioned. Update to a recent version.
(Regarding the log, after running that commabd you should find a dkong.txt file inside mame's folder, that's what you're supposed to attach next time)
Vincefaro
« Reply #5 on: June 05, 2018, 01:43:41 pm »
Oh yeah Sorry, Here it is . Which version should I go up to ?  It says switchres .017g fixed the problem . Does that mean I need the Latest version of GM?
« Last Edit: June 05, 2018, 02:07:08 pm by Vincefaro »
krick
  • Gotta have blue hair.
« Reply #6 on: June 09, 2018, 07:34:17 pm »
I think that 0.194 was the first version with Switchres v0.017g.  So GroovyMAME 0.194 or later should do the trick.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
