Author Topic: Slowdown on interlaced games on 5450  (Read 5955 times)
LazyAce
  • Last login:June 04, 2020, 09:44:45 am
« on: May 26, 2018, 01:08:03 pm »
As above. I know half-speed was an issue, however this doesn't seem to be remedied for me as my card still half-speed all interlaced stuff - is there a fix yet? Many thanks
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
Re: Slowdown on interlaced games on 5450
« Reply #1 on: May 27, 2018, 11:56:18 am »
Hi LazyAce,
Could you indicate on which operating system you encounter this behaviour? Under Linux, there is a remedy to this issue by patching the kernel to allow the vblank to be fired at each frame (odd and even fields). Normally, Groovymame contains the mentioned fix.
bjt42
  • Last login:February 03, 2022, 06:24:37 am
« Reply #2 on: December 03, 2018, 05:47:34 am »
Hi Doozer, would you be able to point me towards this patch please. Thanks
Doozer
  • Z80 ERROR
« Reply #3 on: December 04, 2018, 03:00:53 pm »
Plz dot not flood the forum with same question everywhere ;-) You got PM
bjt42
« Reply #4 on: December 06, 2018, 04:33:25 am »
Doozer's patch solved this problem for me, running a 5450. Here is a 4.10.11 kernel compiled with the 15khz patches and this interlaced vblank fix. It matches the kernel supplied with the 2017 live CD and doesn't suffer from the video playback freezing seen in later kernels.
linux-custom-4.10.11-1-x86_64.pkg.tar.xz: https://drive.google.com/open?id=1i3guHlHfWPNrEhwlz6XF2Xs9Ut9-DUmf
linux-custom-headers-4.10.11-1-x86_64.pkg.tar.xz: https://drive.google.com/open?id=19hxL-5RAmNwprpk6ItMDc3A-SegFrit5
Install as root as follows:
pacman -U linux-custom-headers-4.10.11-1-x86_64.pkg.tar.xz
pacman -U linux-custom-4.10.11-1-x86_64.pkg.tar.xz
Then modify /boot/syslinux/syslinux.cfg to point towards the linux-custom kernel and initrd.
« Last Edit: December 06, 2018, 04:35:34 am by bjt42 »
cobalt666
  • Last login:December 20, 2025, 03:36:28 am
« Reply #5 on: December 07, 2018, 02:13:14 pm »
Hi Doozer, could you please send me this patch as well? I would really appreciate that.
Doozer
  • Z80 ERROR
« Reply #6 on: December 08, 2018, 07:19:14 am »
Yes, sure. The patch is already somewhere on the forum and used inside the GA CD. I enclose it here. It applies up to 4.19.x.
The patch is very simple, it takes all VSYNC interrupts fired by ATI gpu into account. In the stock kernel, the interlaced mode only account the interrupt for a sequence of odd and even fields and has a mechanism to not count int multiple times. ATI sync register is very stable and no overrun occurs since I use it. Let me know if some people have issues.
Code: [Select]
--- linux-4.12_64/drivers/gpu/drm/drm_irq.c     2017-07-02 23:07:02.000000000 +0000
+++ linux-test-4.12/drivers/gpu/drm/drm_irq.c   2017-08-15 08:33:14.318147395 +0000
@@ -243,8 +243,9 @@
                      pipe, vblank->count, diff, cur_vblank, vblank->last);
        if (diff == 0) {
-               WARN_ON_ONCE(cur_vblank != vblank->last);
-               return;
+// AWK         WARN_ON_ONCE(cur_vblank != vblank->last);
+// AWK         return;
+               diff = 1;
