Author Topic: USB Device connection AHK script  (Read 6300 times)
Sky25es
  • Last login:May 23, 2026, 04:51:28 am
« on: May 14, 2018, 12:51:19 pm »
When I designed my control panel, there was the eternal question about the maximum amount of controls I could mount in order to avoid the Frankenpanel problem.
The answer was to add two USB ports on the frontside of the panel so I could connect the adequate control for a specific game.
The biggest problem with this approach is that you have to connect the controller before you launch the emulator (Id's aren't an issue thanks to MAME's ctrl configuration and joyid for the other emus).
I know what kind of devices I need for (near) all my games and that I need to connect them before the emu starts, but other people maybe not...
Therefore, the answer, at least for me, was to create an AHK script that will show a splash screen asking the player to insert the correct USB device into the correct USB port after selecting a game, and only allowing to load that game once connected, or giving the option to go back to the frontend.
I'm using Hyperspin with Rocketlauncher and it works like a charm.
There are surely better ways to achieve this, but it's good enough for me, so I thought I share it cause I wanted to give the community something back. :)
Ok. Now, how it works ?
First of all you will need 3 apps:
- AutoHotkey. Go the official site, download and install it.
- Devcon.exe: The Windows Device Console is a command-line tool that enables, disables, installs, configures, and remove devices.
The executable's name is "devcon.exe". Cause of legal aspects, I can't share the file, but a quick search o Google should help ;)
- USBDeview.exe: USBDeview is a small utility that lists all USB devices that currently
connected to your computer.
Place Devcon.exe in the same folder as the script. If you use a Frontend like Rocketlauncher, place it in the same folder were the Rocketlauncher.exe (I.e.) is.
You can edit the script to your needs with a text editor like notepad.
This is how it works: (Note: the text after the semicolon inside the script serves only as information)
WinHide, ahk_class Shell_TrayWnd
WinHide, Start ahk_class Button
This hides the taskbar. In any case you also have to set the windows task-bar to "autohide" if you don't want to see an empty bar at the bottom of the splash-screen.
SplashImage, Flightstickoff.png, b
Shows the "disconnected " splash-image of your choice for the selected controller. Change "Flightstickoff" to your png image file. Keep in mind that you'll need a image with the resolution of your desktop.
Starting:
RunWait %comspec% /c "devcon status "@USB\VID_045E&PID_001B\6&2aa475d5&0&8">USB_log.txt",,Hide
Calls Devcon to search for USB device Instance ID, creates and saves the status in a textfile: USB_log.txt
You need to search for your device's Instance ID with the app "USBDeview.exe". All connected devices in the list are marked in green. Double-click on your device and copy the data from the "Instance ID" Box. In my case: @USB\VID_045E&PID_001B\6&2aa475d5&0&8.
This will not only indentify the correct controller, but also the USB port you want it connected to.
FileRead, USB, USB_log.txt
Read the USB Device status in the text file "USB_log.txt"
Needle = running
Searches in the text file the word "Running"
IfInstring, USB, running
If the word "Running" is in the textfile, then:
    SplashImage, Flightstickon.png, b  ;Show Splashimage: Flighstickon
    Progress, b w200 y198, Flightstick connected, System OK, My Title
    Progress, 100 ; Set the position of the bar to 50%.
    Sleep, 3000
    Progress, Off
    SplashImage, Off
    WinShow, ahk_class Shell_TrayWnd ;Unhide the Taskbar
    WinShow, Start ahk_class Button  ;Unhide the Taskbar
    ExitApp
Shows the Splash-image "Flightstickon.png". That means that the controller is connected. There's also a progress-bar. Change "Flightstick connected" and "System OK" to whatever you want (I.e. Atari Yoke connected).
You can also change the splash-screen refresh time: change Sleep, 3000 to another number.
else
If the word "Running" is not in the textfile, then:
    Progress, cbred b w200 p0 y150, Flightstick disconnected, please connect the Flightstick to the USB B port as shown or press EXIT to go back, My Title
    Sleep, 2000
    Progress, Off
    Goto, Starting
    Return
Shows the progress bar and asks to connect device or press the exit key (Escape).
As before, you can change the splash-screen refresh time: change Sleep, 3000 to another number and the text in the progress bar too.
Esc::
     Process,Close,RocketLauncher.exe
     ExitApp
Return
If the "Exit" key is pressed, then unhide the Taskbar, quit Rocketlauncher and the script and go back to the Frontend. If you don't use Rocketlauncher with Hyperspin or another Frontend but a single one instead, delete the entry "Process,Close,RocketLauncher.exe".
Change the "Esc" key (Escape) to your needs: A,B,1,7... (Search on the Autohotkey site for keys list)
If you're using Rocketlauncher, the easiest and more convenient way is to insert the script-text inside the AHK script for your emu. Let's take in example MAME:
Open the "Modules" folder. Copy the "MAME" folder to the desktop and rename it to, let's say, "MAMEFlight". Rename the following files to "MAMEFlight" keeping their respective extensions: "MAME.isd", "MAME.ahk" and "MAME.cfg" (this one only if it exists).
Remove from "MAMEFlight.ahk" the MCRC, iCRC, and MID lines.
Insert the script before the StartModule() line. Save the file and put the "MAMEFlight" folder back to the "Modules" folder.
Start "RocketlauncherUI", select MAME in the left column and in the "Emulators" Tab, add a new Emu and Name it I.e. "MameFlight" with the same parameters like your "MAME" emu added before.
On the "Games" Tab click on "Alternate Emulators" and add the game or games that will use this particular controller, choosing as the emu "Mameflight".
As a standalone script for other frontends, insert Run (Your Game-directory/Executable), I.e: Run C:\Program Files\Putty\putty.exe , after the line "SplashImage, Off".
After that insert the last line: ExitApp
Example:
Return
Next:
SplashImage, Off
ExitApp
I've included 4 example scripts. 2 for Mame-Rocketlauncher and 2 standalone.
2 of them are examples for 1 or 2 gamepad connections (4 players, 2 gamepads & 2 control panel Joysticks).
Here some splash-screen examples:
« Last Edit: May 15, 2018, 09:33:36 pm by Sky25es »
