Author Topic: MAME 0.196 compiler warnings  (Read 2819 times)
EMDB
  • Project RetroCade
« on: April 16, 2018, 01:19:02 pm »
When I try to compile  MAME 0.196 with the no-nag patch (http://mamestuff.lowtrucks.net/MKChamp/) using the latest Mame Compiler 64 (V2.0.176) I get a lot of warnings during the build. The build finishes though and a new version om MAME is created. It even seems to work but I'm in doubt about the warnings. It looks like 2 warnings about deprecated stuff repeating in all kind of drivers:
Anybody a clue?  ???  ???
Robbbert
  • Last login:July 02, 2026, 08:51:40 pm
Re: MAME 0.196 compiler warnings
« Reply #1 on: April 16, 2018, 06:30:58 pm »
Yes... ignore them all. There will most likely be even more warnings for 0.197.
Specifically "set_digit_value" was deprecated (causes the warnings) and has now been eliminated. However "set_led_value" and "set_lamp_value" are newly added, so creating even more warnings. Plus a single warning about a CPU.
So, as long as your build gets created at the end, there's nothing to worry about.
