Author Topic: Tempest 4000  (Read 10156 times)
shaolindrunkard
  • Last login:February 12, 2026, 11:54:11 am
Tempest 4000
« on: April 02, 2018, 07:35:52 pm »
Just discovered this, not sure if its going to work with a spinner, but its interesting...
http://store.steampowered.com/app/688140/Tempest_4000/
Re: Tempest 4000
« Reply #1 on: April 02, 2018, 11:06:25 pm »
It looks a little busy but I'll buy it if it works with a spinner.  Jeff Minter makes some cool games.
Re: Tempest 4000
« Reply #2 on: April 03, 2018, 02:15:53 pm »
It should work with a spinner since it works with a mouse.  I have the original Free version called "Typhoon 2001" that was made years ago.  It worked great on my cabinet with a spinner.
Goodle Typhoon 2001 and you should be able to find the free program hosted somewhere.  I'm glad that he updated it and commercialized it though.  It really is a cool game.
DeL
shaolindrunkard
Re: Tempest 4000
« Reply #3 on: April 03, 2018, 02:57:47 pm »
DeL
Yeah I've played it, its really great especially since its free. Only thing we don't know yet for this game is the extent of the mouse options, hopefully he thought to put the same options like sensitivity, reverse axis... into this new game just like there was in Typhoon.
Re: Tempest 4000
« Reply #4 on: April 03, 2018, 03:44:34 pm »
DeL
This is good to know.  Are there other fun "modernish" spinner PC games out there?  I have an extra spinner I wouldn't mind building something around.
8BitMonk
Re: Tempest 4000
« Reply #5 on: April 03, 2018, 05:52:06 pm »
Definitely going in my Tempest cabaret! I couldn't find an original vector monitor to fully restore it so I'm putting in a rotatable LCD as well as other spinner games. Will be nice to have this running alongside the original Tempest even if it is on an LCD.
shaolindrunkard
Re: Tempest 4000
« Reply #6 on: April 03, 2018, 06:58:30 pm »
DeL
The only other one I know of is Luxor.
Tempest Nut
  • Last login:May 26, 2020, 01:02:20 am
Re: Tempest 4000
« Reply #7 on: May 26, 2020, 12:49:11 am »
I have a version of Tempest 4000 PC that will work with a spinner...
jlfreund
  • Last login:June 12, 2025, 02:25:33 pm
    • My project's blog
Re: Tempest 4000
« Reply #8 on: June 11, 2020, 10:18:22 pm »
This is a great find.  Can you elaborate on "version"?  Will any build of Tempest 4K support a spinner, and if so, how did you configure it, and how well does it play?
Re: Tempest 4000
« Reply #9 on: June 12, 2020, 08:20:47 pm »
Last I checked it didn't. (Can't remember exactly).  It was built for Direct input, such as an Xbox controller or similar.
Again, I am going by memory so don't quote me.  However, I do remember it be disappointing.
Sent from my moto z3 using Tapatalk
SORHP
  • Last login:April 30, 2026, 06:41:43 pm
Re: Tempest 4000
« Reply #10 on: June 12, 2020, 09:53:03 pm »
Hey, checking in, could you please inform us on how to implement a usb spinner Interface?
Games: Super Punch Out, Fix It Felix Jr, DK, DKjr, DK3, PC10, UMK3, TRON, MS-Pac, Pac, Centipede (2x), Robotron, Galaga, Space Invaders, Street Fighter 2 CE, X-Men vs SF, BuckHunter HD, 2X Custom Vewlix, Custom Nintendo VS 3/4, Atomiswave
negative1
  • Last login:June 23, 2026, 08:46:26 pm
Re: Tempest 4000
« Reply #11 on: June 12, 2020, 10:59:05 pm »
with pc spinner:
if you want some alternate methods :
https://steamcommunity.com/app/688140/discussions/0/2803982773085897832/
Since I've been terribly frustrated with the lack of spinner support, I had an idea to add it to this game using AutoHotkey to intercept X coordinates from mouse movement and translate them into left/right keystrokes.
The good news is that it *almost* works. I'm close. The problem I'm dealing with right now is looping back to the center when the cursor hits the edge of the screen.
Here's my code as of right now:;
Code: [Select]
Coordmode,Mouse,Screen
MonitorMouseMovement := True
SetTimer,CheckMouseMovement,1
Return
*~1::
Return
CheckMouseMovement()
Global MonitorMouseMovement
Static OldX
MouseGetPos,CurrentX,CurrentY
If (CurrentX != OldX){
if (OldX < CurrentX) {
Send, {right}
MouseMove, 500, 500,0
OldX:= CurrentX
else if (OldX > CurrentX) {
Send, {left}
OldX:= CurrentX
CheckMouseMovement:
If (!CheckMouseMovement())
Return
If you've never used AutoHotKey, it's a super powerful scripting tool for Windows. It's free and easy to use.
If I get this working I'll add a launch command for T4K and post it somewhere. And if anyone has any suggestions for getting the loopback to work, I'd love to hear it. It seems like the mouse moves too quickly for AHK to constantly shove it back to the center of the screen.
NOTE : NOT MY CODE
it was cut and pasted from the steam thread, all credit to the original poster
later
-1
« Last Edit: June 14, 2020, 12:23:30 am by negative1 »
nexusmtz
  • Last login:June 10, 2026, 11:25:24 pm
Re: Tempest 4000
« Reply #12 on: June 13, 2020, 02:22:24 am »
If you're forcing the mouse back to 500,500, OldX should be set to 500 (or you should be comparing CurrentX to 500.)
Also, you should be sending a number of left or right strokes proportionate to the difference between CurrentX and 500. That way you're emulating the analog nature of the control. (but I doubt the game will react to that many strokes anyway)
If you're not trying to emulate analog control, you should be sending [left key up, right key down] on >500, [right key up, left key down] on <500 and both up on equal. (but that's no better than using a joystick or buttons)
negative1
Re: Tempest 4000
« Reply #13 on: June 17, 2020, 02:10:03 pm »
I tried out the new PC Binary with spinner control.
It works as advertised.
Did a binary compare with the Windows 7/8 Binary,
and its very different, so it's not just a tiny patch
to the EXE. There are major sections changed.
The filesize is 1.7k, and the original is 1.6k.
later
-1
Re: Tempest 4000
« Reply #14 on: July 27, 2020, 02:37:47 am »
later
-1
What do you mean by new PC binary? Is this an official patch?
negative1
Re: Tempest 4000
« Reply #15 on: November 26, 2020, 08:35:03 pm »
the pc version is on sale at steam 75% off, so its $4.99
https://store.steampowered.com/app/688140/Tempest_4000/?snr=1_7_7_151_150_1
later
-1
zeorangr
  • Last login:June 06, 2026, 10:27:25 am
    • forum.arcadecontrols.com/index.php/topic,165836.0.html
Re: Tempest 4000
« Reply #16 on: November 22, 2022, 08:39:02 am »
later
-1
Hey all - sorry for the thread necromancy, but I was wondering if this 'patch' or updated .exe or whatever to add spinner support for Tempest 4000 is available somewhere?  I've tried looking around via google, and I see several posts around the web from Tempest Nut alluding to a patch, but no links to an actual download for this.  Does anyone have a copy, or could someone point me to where I might find this?
I'd love to get this game working with a proper spinner if possible.
Thanks.
-z-
