Author Topic: J-Stick issue  (Read 2176 times)
str1der
  • Last login:March 04, 2021, 04:35:31 pm
  • Live it!
J-Stick issue
« on: February 03, 2004, 02:32:38 pm »
Do any of you guys have trouble with the ball on your J-Stick constantly unscrewing? Have come up with a solution?
NoOne=NBA=
Re:J-Stick issue
« Reply #1 on: February 03, 2004, 02:42:09 pm »
Other than Epoxy, you mean?
(See sig for details).
Seriously though, you might try some Loc-Tite threadlocker on it.
It's not as good as epoxy; but isn't as permanent, either.
IG-88
Re:J-Stick issue
« Reply #2 on: February 03, 2004, 02:56:13 pm »
Yep Lock-tite. You can get it back off if needed.
-HarumaN
str1der
  • Live it!
Re:J-Stick issue
« Reply #3 on: February 03, 2004, 03:17:54 pm »
Thanks. I assume I can get that at the harware store?
Stingray
Re:J-Stick issue
« Reply #4 on: February 03, 2004, 03:19:33 pm »
I know for sure you can get it at auto parts places like NAPA or Autozone.
-S
Wade
  • Last login:March 08, 2026, 03:31:11 pm
  • 80's Child
    • Wade's Gameroom
Re:J-Stick issue
« Reply #5 on: February 03, 2004, 03:32:58 pm »
I had this problem initially, but then I grabbed the botton end of the shaft with some pliers, and twisted the knob on real tight with my hand.  They haven't worked loose ever since!
Wade
NoOne=NBA=
Re:J-Stick issue
« Reply #6 on: February 03, 2004, 04:44:12 pm »
You don't get to stink up the house that way though.  ;D
I tend to follow the redneck way of repairing things:
1) If it moves, and it ain't 'spose to--use Duck Tape or Epoxy.
2) If it don't move, and it's 'spose to--git out the WD-40.
2a) If it still don't move--git a bigger hammer.
It WILL move--trust me.
canardo
  • Last login:January 01, 2008, 07:32:23 am
Re:J-Stick issue
« Reply #7 on: February 03, 2004, 06:44:12 pm »
as stated get some pliers and hold the metal stalk and then do it up worked for me
IG-88
Re:J-Stick issue
« Reply #8 on: February 03, 2004, 07:23:14 pm »
I think I've even seen it at Wal-Mart
-HarumaN
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:J-Stick issue
« Reply #9 on: February 03, 2004, 11:21:29 pm »
Doesn't the j-stick shaft have a groove at the bottom that is perfect for a flat head screw driver to help you hold the shaft steady whilst you crank down the ball?
rampy
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re:J-Stick issue
« Reply #10 on: February 04, 2004, 04:26:12 am »
rampy
Absolutely! That's exactly what the slot is for..
Andy
paigeoliver
  • Awesome face!
Re:J-Stick issue
« Reply #11 on: February 04, 2004, 07:30:35 am »
The ball on my Do! Run Run does this same thing, thanks for the tips.
Wade
  • 80's Child
    • Wade's Gameroom
Re:J-Stick issue
« Reply #12 on: February 04, 2004, 09:20:24 am »
Yeah, sorry, I used the screwdriver not pliers... was just going from memory. :)
Wade
