Author Topic: Smart Power strip for system startup?  (Read 3559 times)
bperkins01
« on: March 17, 2018, 07:00:52 pm »
Hi Everyone,
Are the smart strips still the best way to turn everything on?  i.e.  PC power up triggers the strip to provide power to everything else..
Or is there a better - cooler way now?
It looks like there are strips out there where you can control the outlets via an app too..
Any recommendations on strips?
I haven't found a recent thread on the topic via search..  I'm at the point there I need to get one set up.
Bob
cj138
  • Last login:May 23, 2018, 06:56:39 pm
Re: Smart Power strip for system startup?
« Reply #1 on: March 17, 2018, 07:32:57 pm »
I have done something like this.
bperkins01
« Reply #2 on: March 17, 2018, 09:10:41 pm »
Thanks - I'll be doing that too.
I finally found the old threads -
Power Strip
I think this will do the trick..
djfender
  • Last login:April 13, 2020, 04:13:15 pm
  • I play with sega, not ladies' hearts.
« Reply #3 on: March 17, 2018, 09:22:35 pm »
I used the "restore power after blackout" function on my motherboard, with a monitor that goes to sleep after a while of no signal, and ran my audio of 12v from the pc psu.
You could use an RF power thingy meant for Christmas lights ive done that before.
Is that a Sanwa in your pocket or are you just happy to see me?
"Hotrodded" Hanaho Hotrod w/Kade MiniArcade 2.0 on Leonardo
« Reply #4 on: March 19, 2018, 12:41:50 pm »
With a PC the smart strip is still the best way (for a CRT monitor).  However, if you have a PCB and switching power supply you don't really need it.  Or an LCD for that matter since it goes into sleep mode.
Here's a video a did a LOOOONG time ago with my setup that still works to this day:
DeL
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
« Reply #5 on: March 19, 2018, 03:23:04 pm »
Hi Everyone,
Bob
If you want to use an app, you could use something like Sonoff relays.
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
