Author Topic: You Don't Know Jack Webisodes (2007)  (Read 1976 times)
Derrick Renaud
  • Last login:December 06, 2024, 04:31:44 pm
« on: March 11, 2018, 03:36:03 pm »
Don't know if anyone is interested but the You Don't Know Jack Webisodes are on archive.org.
https://archive.org/details/YDJK-web-episodes-2007
You need to have flash installed.  The zip has some basic HTML files to access the games.
I want them full screen, so I wrote up a quick autohotkey script launch them full screen and increment after each play.
Press Escape to quit and increment or F10 to quit without increment.
You will need the flash projector available here:
https://www.adobe.com/support/flashplayer/debug_downloads.html
Specifically the file flashplayer_28_sa.exe here:
https://fpdownload.macromedia.com/pub/flashplayer/updaters/28/flashplayer_28_sa.exe
Unzip the webisode archives.  Put flashplayer_28_sa.exe & the attached script in the folder with all the HTML files.
Then run YDKJ.
If anyone knows how to pass multiple parameters to the flash projector, then we could add the other variables like play count.
For now I could only get 1 variable to work, so I chose to pass the episode #.
« Last Edit: March 12, 2018, 10:44:59 am by Derrick Renaud »
