Author Topic: Working with lexan?  (Read 1360 times)
Pete Harcoff
  • Last login:May 29, 2005, 07:47:46 pm
Working with lexan?
« on: February 03, 2004, 01:15:42 am »
I'm thinking of (eventually) covering the surface of my controller with 1/4" or 1/8" lexan.
How easy is lexan to work with?  What tools are needed for cutting and drilling it?  And how expensive is it?
« Last Edit: February 03, 2004, 01:30:15 am by Pete Harcoff »
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
Re:Working with lexan?
« Reply #1 on: February 03, 2004, 02:57:03 am »
1/4" is pretty thick...
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #2 on: February 03, 2004, 03:53:25 am »
I've had no problems drilling or cutting Lexan. It's much easier to work with then Plexi.
I did hav a lot of problems bending it though. I wanted to make a rounded front on my CP and I didn't get that done right (bubbling and uneven bending). I tried to make a Galaga CP covered in Lexan.
NoOne=NBA=
« Reply #3 on: February 03, 2004, 07:34:13 am »
Lexan is alot easier to work with than Plexi (Acrylic).
Acrylic will shatter if you aren't careful with it; and even occasionally when you are.
As far as cutting and drilling Lexan, you don't need any special tools, just patience.
I would recommend the finest tooth saw you and get when cutting it.
The trick to an even bend with Lexan is even heat.
We used to have a heater at work for bending sheets that was basically a bunch of these mesh heater elements between some nails on a board.
You plugged it in, and set the Lexan on it until the area you wanted to bend got hot, then you'd wrap it as quickly as possible around.
I've tried forming it using a brazing torch since then, and it's tough to get a nice even bend.
