Author Topic: Rowe Ami Cadette, not turning off when disc played, reject button not operating  (Read 2859 times)
Just John
  • Last login:February 27, 2018, 11:42:02 am
Played about a dozen 45's fine, then stuck at end of one, arm moved across but does not shut off or go into next sequence,  eject button does not have any effect, turned power off and restarted, but turntable continues to play and arm in end of 45, but not shutting off . . .?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Hello John,
Haveyou checked the 30 volt DC supply has not tripped out or blown a fuse on an earlier power supply (junction box)?
Try turning the transfer motor manually to see if it is jammed.
Regards
Alan
