Author Topic: Hooking Arcade Power switch back up  (Read 1752 times)
jkimrey
  • Last login:February 14, 2021, 08:58:41 am
« on: February 25, 2018, 04:22:56 pm »
I recently removed my marquee light (and associated wiring with it) and totally forgot how the power switch was wired (should have taken pictures).  ???
I know the white connector connects to the cords coming up from the power supply, but there are two other connectors (one with two wires coming in), and the switch itself has a place for two connections.
The first pic shows the switch, the second the white connector that connects to the wires coming from the power supply.
The third picture shows one connector coming from the white connector with two wires.  The next pic shows the single wire connector.
For good measure the last two pics show how the marquee light was set up.
Any suggestions on how I should wire the switch without the marquee?  The last thing I want to do at this point is wire something wrong and fry all my hard work. :)
TIA
