Author Topic: Electric ICE 2-CX (Micro-Leaf) buttons with IPac2 - wiring questions.  (Read 2119 times)
Gryizor
  • Last login:February 20, 2018, 04:24:22 pm
Hi all,
I hope someone in here can help me:
I recently ordered a LED-Wiz and  Electric ICE 2-CX (Micro-Leaf) buttons from GroovyGameGear, and a separate IPac2 for a pinball project.
The buttons have all been hooked up with LED-Wiz and all lights are working fine. I am however in doubt how to connect the Micro-Leaf buttons to the IPac2 since all of them come with three pins (and not two like Sanwa buttons for instance) for connection with the spade/crimp-wire.
Looking at the Micro-Leaf switch, I can see the pins having the numbers 1, 3 and 2.
Can anyone tell me which of the three pins should be used for connecting with the IPac2 and which one should be used for "Ground" ?
Thanks.
« Last Edit: February 19, 2018, 05:37:46 pm by Gryizor »
  • Last login:Today at 02:25:37 am
Re: Electric ICE 2-CX (Micro-Leaf) buttons with IPac2 - wiring questions.
« Reply #1 on: February 19, 2018, 05:53:30 pm »
Teminal tabs on the MicroLeaf: (left to right)
Normally Closed (NC)  Normally Open (NO)               Common (COM)
Connect NO to the I-Pac input and connect COM to the daisy-chain ground.
The NC tab is *usually* not used.
Gryizor
« Reply #2 on: February 20, 2018, 04:25:16 pm »
@PL1: Thank you, this was exactly what I needed. Much appreciated.
