Author Topic: Rowe record selection issue  (Read 3127 times)
jefferson1975
  • Last login:May 08, 2020, 12:29:09 pm
« on: February 19, 2018, 11:08:06 am »
Hello,
I have a Rowe R-83. Whenever I choose record 127/227 it always goes to 128/228. Every other record selection is fine. Any thoughts on what is causing this issue?
Jeff
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe record selection issue
« Reply #1 on: February 27, 2018, 05:47:00 am »
Hello Jeff,
If all the other selections are fine I would be looking at the encoder printed circuit board for any defects at that location.
Regards
Alan
Alan Hood
ami-man
UK
jefferson1975
« Reply #2 on: February 28, 2018, 10:38:02 am »
Thanks Alan. I'll take a look. On a side note, I currently have a 1200 mechanism tonearm in my Rowe R-83. I'd like to get the correct 125 watt amp. However, the phono/amp cables are different for the 125 amp. Mine has the round plug on the tonearm and the Left/Right RCA plugs into the amp.  Is there any way to use my current 1200 mechanism tonearm with the 125 watt amp?
Jeff
« Last Edit: February 28, 2018, 10:40:42 am by jefferson1975 »
ami-man
« Reply #3 on: March 26, 2018, 08:30:25 am »
Hello Jeff,
You have to remove the phono connection on the loom and fitt a three pin connector. The cartridge connections have to be changed so there are in phase, they will be wired out of phase currently.
Regards
Alan
Alan Hood
ami-man
UK
