Author Topic: Modelines/D9800  (Read 1899 times)
thevidiot
  • Last login:September 13, 2024, 02:23:09 pm
Modelines/D9800
« on: February 04, 2018, 12:21:20 pm »
Hello.  After years of struggle with an ArcadeVGA 3000, I switched to GroovyMAME and CRT Emudriver,  Using 0.193 and [CRT Emudriver 2.0][CRT Tools 2.0][beta 12].  I have a D9800 and HD 6700 card.  The results were excellent!  I had a question, however.  When I ran VMMaker, it generated 30 modelines.  Is that an expected number?  I ask because when I run many games QuickRes shows minor differences between the MAME resolution and what it uses.  So, in some cases, there is minor clipping of vertical or horizontal images.
My machine is off site, or I would attach a report, but thought I'd check my setup was okay first.
Thank you
thevidiot
Re: Modelines/D9800
« Reply #1 on: February 05, 2018, 05:39:35 pm »
Below is a debug file, apologies for the inline text -- I am too new for uploading, I believe.  Thanks for checking!
SwitchRes: v0.017f, Monitor: custom, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Monitor range 15250.00-18000.00,40.00-80.00,2.187,4.688,6.719,0.190,0.191,1.018,0,0,224,288,448,576
SwitchRes: Monitor range 18001.00-19000.00,40.00-80.00,2.187,4.688,6.719,0.140,0.191,0.950,0,0,288,320,0,0
SwitchRes: Monitor range 20501.00-29000.00,40.00-80.00,2.910,3.000,4.440,0.451,0.164,1.048,0,0,320,384,0,0
SwitchRes: Monitor range 29001.00-32000.00,40.00-80.00,0.636,3.813,1.906,0.318,0.064,1.048,0,0,384,480,0,0
SwitchRes: Monitor range 32001.00-34000.00,40.00-80.00,0.636,3.813,1.906,0.020,0.106,0.607,0,0,480,576,0,0
SwitchRes: Monitor range 34001.00-38000.00,40.00-80.00,1.000,3.200,2.200,0.020,0.106,0.607,0,0,576,600,0,0
SwitchRes: \\.\DISPLAY1: AMD Radeon HD 6700 Series (PCI\VEN_1002&DEV_68BA&SUBSYS_21421462&REV_00)
SwitchRes: Device key: System\CurrentControlSet\Control\Video\{5ACE7DB5-00C8-42FB-8814-4E1B31760065}\0000
ATI/AMD ADL init
Catalyst Version 15.8
ADL functions retrieved successfully.
Switchres: Searching for custom video modes...
Switchres: [  1]  640x 480 @ 60* : ATI ADL timing "640x480_60 31.500000KHz 60.000000Hz" 25.200000 640 656 752 800 480 490 492 525   -hsync -vsync
Switchres: [  2] 2560x 240 @ 60 : ATI ADL timing "2560x240_60 15.718000KHz 59.992367Hz" 51.180000 2560 2672 2912 3256 240 243 246 262   -hsync -vsync
Switchres: [  3] 2560x 248 @ 60 : ATI ADL timing "2560x248_60 16.259000KHz 59.996311Hz" 53.460000 2560 2680 2928 3288 248 252 255 271   -hsync -vsync
Switchres: [  4] 2560x 256 @ 60 : ATI ADL timing "2560x256_60 16.740000KHz 60.000000Hz" 55.310000 2560 2680 2936 3304 256 259 262 279   -hsync -vsync
Switchres: [  5] 2560x 264 @ 60 : ATI ADL timing "2560x264_60 17.279000KHz 59.996529Hz" 57.920000 2560 2688 2960 3352 264 267 270 288   -hsync -vsync
Switchres: [  6] 2560x 272 @ 60 : ATI ADL timing "2560x272_60 17.820000KHz 60.000000Hz" 60.020000 2560 2688 2968 3368 272 276 279 297   -hsync -vsync
Switchres: [  7] 2560x 280 @ 59 : ATI ADL timing "2560x280_59 18.001000KHz 59.019672Hz" 61.060000 2560 2696 2984 3392 280 283 286 305   -hsync -vsync
Switchres: [  8] 2560x 288 @ 60 : ATI ADL timing "2560x288_60 18.720000KHz 60.000000Hz" 64.400000 2560 2704 3008 3440 288 291 295 312   -hsync -vsync
Switchres: [  9] 2560x 296 @ 59 : ATI ADL timing "2560x296_59 18.999000KHz 59.371876Hz" 65.510000 2560 2704 3008 3448 296 299 303 320   -hsync -vsync
Switchres: [ 10] 2560x 304 @ 58 : ATI ADL timing "2560x304_58 18.999000KHz 57.923782Hz" 65.510000 2560 2704 3008 3448 304 307 311 328   -hsync -vsync
Switchres: [ 11] 2560x 320 @ 60 : ATI ADL timing "2560x320_60 21.298000KHz 59.994366Hz" 69.860000 2560 2760 2968 3280 320 330 333 355   -hsync -vsync
Switchres: [ 12] 2560x 336 @ 60 : ATI ADL timing "2560x336_60 22.379000KHz 59.997318Hz" 74.480000 2560 2776 3000 3328 336 346 350 373   -hsync -vsync
Switchres: [ 13] 2560x 344 @ 60 : ATI ADL timing "2560x344_60 22.919000KHz 59.997383Hz" 77.010000 2560 2784 3016 3360 344 354 358 382   -hsync -vsync
Switchres: [ 14] 2560x 352 @ 60 : ATI ADL timing "2560x352_60 23.460000KHz 60.000000Hz" 79.390000 2560 2792 3032 3384 352 363 367 391   -hsync -vsync
Switchres: [ 15] 2560x 360 @ 60 : ATI ADL timing "2560x360_60 23.999000KHz 59.997501Hz" 81.790000 2560 2800 3048 3408 360 371 375 400   -hsync -vsync
Switchres: [ 16] 2560x 368 @ 60 : ATI ADL timing "2560x368_60 24.540000KHz 60.000000Hz" 84.420000 2560 2808 3064 3440 368 380 384 409   -hsync -vsync
Switchres: [ 17] 2560x 376 @ 60 : ATI ADL timing "2560x376_60 25.081000KHz 60.002392Hz" 86.480000 2560 2808 3064 3448 376 388 392 418   -hsync -vsync
Switchres: [ 18] 2560x 384 @ 60 : ATI ADL timing "2560x384_60 25.619000KHz 59.997658Hz" 88.950000 2560 2816 3080 3472 384 396 400 427   -hsync -vsync
Switchres: [ 19] 2560x 392 @ 60 : ATI ADL timing "2560x392_60 29.040000KHz 60.000000Hz" 91.070000 2560 2616 2960 3136 392 427 429 484   -hsync -vsync
Switchres: [ 20] 2560x 400 @ 60 : ATI ADL timing "2560x400_60 29.040000KHz 60.000000Hz" 91.070000 2560 2616 2960 3136 400 431 433 484   -hsync -vsync
Switchres: [ 21] 2560x 416 @ 60 : ATI ADL timing "2560x416_60 29.040000KHz 60.000000Hz" 91.070000 2560 2616 2960 3136 416 439 441 484   -hsync -vsync
Switchres: [ 22] 2560x 432 @ 60 : ATI ADL timing "2560x432_60 29.040000KHz 60.000000Hz" 91.070000 2560 2616 2960 3136 432 447 449 484   -hsync -vsync
Switchres: [ 23] 2560x 448 @ 60 : ATI ADL timing "2560x448_60 29.398000KHz 59.995918Hz" 92.430000 2560 2616 2968 3144 448 457 459 490   -hsync -vsync
Switchres: [ 24] 2560x 464 @ 60 : ATI ADL timing "2560x464_60 30.478000KHz 59.996063Hz" 96.800000 2560 2624 2992 3176 464 474 476 508   -hsync -vsync
Switchres: [ 25] 2560x 480 @ 60 : ATI ADL timing "2560x480_60 31.500000KHz 60.000000Hz" 100.800000 2560 2624 3008 3200 480 490 492 525   -hsync -vsync
Switchres: [ 26] 2560x 496 @ 60 : ATI ADL timing "2560x496_60 32.038000KHz 59.996254Hz" 102.780000 2560 2624 3016 3208 496 504 507 534   -hsync -vsync
Switchres: [ 27] 2560x 512 @ 60 : ATI ADL timing "2560x512_60 32.161000KHz 60.001865Hz" 103.430000 2560 2624 3016 3216 512 513 516 536   -hsync -vsync
Switchres: [ 28] 2560x 544 @ 60 : ATI ADL timing "2560x544_60 34.001000KHz 59.755711Hz" 110.980000 2560 2632 3056 3264 544 545 549 569   -hsync -vsync
Switchres: [ 29] 2560x 560 @ 58 : ATI ADL timing "2560x560_58 34.001000KHz 58.121368Hz" 110.980000 2560 2632 3056 3264 560 561 565 585   -hsync -vsync
Switchres: [ 30] 2560x 600 @ 60 : ATI ADL timing "2560x600_60 37.680000KHz 60.000000Hz" 127.210000 2560 2688 3096 3376 600 601 605 628   -hsync -vsync
SwitchRes: Found 30 custom of 30 active video modes
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.017f:[trackfld] Calculating best video mode for 256x224@60.000000 orientation: normal
SwitchRes: [ 640]x[ 480]_[60=60.000000Hz]
   rng(0):  out of range
   rng(1):  out of range
   rng(2):  out of range
   rng(3):  640 x 480_60.000000p 31.500000 [fract] scale(2, 2, 1) diff(20.00, 6.67, 0.0000) ratio(2.500, 2.143)
   rng(4):  640 x 480_60.000000p 31.500000 [fract] scale(2, 2, 1) diff(20.00, 5.99, 0.0000) ratio(2.500, 2.143)
   rng(5):  out of range
SwitchRes: [2560]x[ 240]_(60=59.992367Hz)
   rng(0): 2560 x 240_60.000000p 15.720000 [integ] scale(10, 1, 1) diff(0.00, 2.67, 0.0000) ratio(10.000, 1.071)
   rng(3):  out of range
   rng(4):  out of range
SwitchRes: [2560]x[ 248]_(60=59.996311Hz)
   rng(0): 2560 x 248_60.000000p 16.260000 [integ] scale(10, 1, 1) diff(0.00, 5.90, 0.0000) ratio(10.000, 1.107)
SwitchRes: [2560]x[ 256]_(60=60.000000Hz)
   rng(0): 2560 x 256_60.000000p 16.740000 [integ] scale(10, 1, 1) diff(0.00, 8.60, 0.0000) ratio(10.000, 1.143)
SwitchRes: [2560]x[ 264]_(60=59.996529Hz)
   rng(0): 2560 x 264_60.000000p 17.280000 [fract] scale(10, 1, 1) diff(0.00, 11.46, 0.0000) ratio(10.000, 1.179)
SwitchRes: [2560]x[ 272]_(60=60.000000Hz)
   rng(0): 2560 x 272_60.000000p 17.820000 [fract] scale(10, 1, 1) diff(0.00, 14.14, 0.0000) ratio(10.000, 1.214)
SwitchRes: [2560]x[ 280]_(59=59.019672Hz)
   rng(0): 2560 x 280_59.016392p 17.999999 [fract] scale(10, 1, 1) diff(0.00, 16.39, -0.9836) ratio(10.000, 1.250)
SwitchRes: [2560]x[ 288]_(60=60.000000Hz)
   rng(0): 2560 x 288_57.507988p 18.000000 [fract] scale(10, 1, 1) diff(0.00, 18.53, -2.4920) ratio(10.000, 1.286)
   rng(1): 2560 x 288_60.000000p 18.720000 [fract] scale(10, 1, 1) diff(0.00, 24.04, 0.0000) ratio(10.000, 1.286)
SwitchRes: [2560]x[ 296]_(59=59.371876Hz)
   rng(1): 2560 x 296_59.375000p 19.000000 [fract] scale(10, 1, 1) diff(0.00, 25.94, -0.6250) ratio(10.000, 1.321)
SwitchRes: [2560]x[ 304]_(58=57.923782Hz)
   rng(1): 2560 x 304_57.926830p 19.000000 [fract] scale(10, 1, 1) diff(0.00, 27.74, -2.0732) ratio(10.000, 1.357)
SwitchRes: [2560]x[ 320]_(60=59.994366Hz)
   rng(1): 2560 x 320_55.232559p 19.000000 [fract] scale(10, 1, 1) diff(0.00, 31.10, -4.7674) ratio(10.000, 1.429)
   rng(2): 2560 x 320_60.000000p 21.300000 [fract] scale(10, 1, 1) diff(0.00, 30.70, 0.0000) ratio(10.000, 1.429)
SwitchRes: [2560]x[ 336]_(60=59.997318Hz)
   rng(2): 2560 x 336_60.000000p 22.380000 [fract] scale(10, 1, 1) diff(0.00, 34.05, 0.0000) ratio(10.000, 1.500)
SwitchRes: [2560]x[ 344]_(60=59.997383Hz)
   rng(2): 2560 x 344_60.000000p 22.920000 [fract] scale(10, 1, 1) diff(0.00, 35.60, 0.0000) ratio(10.000, 1.536)
SwitchRes: [2560]x[ 352]_(60=60.000000Hz)
   rng(2): 2560 x 352_60.000000p 23.460000 [fract] scale(10, 1, 1) diff(0.00, 37.08, 0.0000) ratio(10.000, 1.571)
SwitchRes: [2560]x[ 360]_(60=59.997501Hz)
   rng(2): 2560 x 360_60.000000p 24.000000 [fract] scale(10, 1, 1) diff(0.00, 38.50, 0.0000) ratio(10.000, 1.607)
SwitchRes: [2560]x[ 368]_(60=60.000000Hz)
   rng(2): 2560 x 368_60.000000p 24.540000 [fract] scale(10, 1, 1) diff(0.00, 39.85, 0.0000) ratio(10.000, 1.643)
SwitchRes: [2560]x[ 376]_(60=60.002392Hz)
   rng(2): 2560 x 376_60.000000p 25.080000 [fract] scale(10, 1, 1) diff(0.00, 41.15, 0.0000) ratio(10.000, 1.679)
SwitchRes: [2560]x[ 384]_(60=59.997658Hz)
   rng(2): 2560 x 384_60.000000p 25.620000 [fract] scale(10, 1, 1) diff(0.00, 42.39, 0.0000) ratio(10.000, 1.714)
   rng(3): 2560 x 384_60.000000p 29.040000 [fract] scale(10, 1, 1) diff(0.00, 33.06, 0.0000) ratio(10.000, 1.714)
SwitchRes: [2560]x[ 392]_(60=60.000000Hz)
   rng(3): 2560 x 392_60.000000p 29.040000 [fract] scale(10, 1, 1) diff(0.00, 33.06, 0.0000) ratio(10.000, 1.750)
SwitchRes: [2560]x[ 400]_(60=60.000000Hz)
   rng(3): 2560 x 400_60.000000p 29.040000 [fract] scale(10, 1, 1) diff(0.00, 33.06, 0.0000) ratio(10.000, 1.786)
SwitchRes: [2560]x[ 416]_(60=60.000000Hz)
   rng(3): 2560 x 416_60.000000p 29.040000 [fract] scale(10, 1, 1) diff(0.00, 33.06, 0.0000) ratio(10.000, 1.857)
SwitchRes: [2560]x[ 432]_(60=60.000000Hz)
   rng(3): 2560 x 432_60.000000p 29.040000 [fract] scale(10, 1, 1) diff(0.00, 33.06, 0.0000) ratio(10.000, 1.929)
SwitchRes: [2560]x[ 448]_(60=59.995918Hz)
   rng(0): 2560 x 448_60.000000i 15.330000 [integ] scale(10, 2, 1) diff(0.00, 0.00, 0.0000) ratio(10.000, 2.000)
   rng(3): 2560 x 448_60.000000p 29.400000 [integ] scale(10, 2, 1) diff(0.00, 0.00, 0.0000) ratio(10.000, 2.000)
SwitchRes: [2560]x[ 464]_(60=59.996063Hz)
   rng(0): 2560 x 464_60.000000i 15.330000 [integ] scale(10, 2, 1) diff(0.00, 0.00, 0.0000) ratio(10.000, 2.071)
   rng(3): 2560 x 464_60.000000p 30.480000 [integ] scale(10, 2, 1) diff(0.00, 3.54, 0.0000) ratio(10.000, 2.071)
SwitchRes: [2560]x[ 480]_(60=60.000000Hz)
   rng(0): 2560 x 480_60.000000i 15.750000 [integ] scale(10, 2, 1) diff(0.00, 2.67, 0.0000) ratio(10.000, 2.143)
   rng(3): 2560 x 480_60.000000p 31.500000 [integ] scale(10, 2, 1) diff(0.00, 6.67, 0.0000) ratio(10.000, 2.143)
   rng(4): 2560 x 480_60.000000p 32.040000 [integ] scale(10, 2, 1) diff(0.00, 5.99, 0.0000) ratio(10.000, 2.143)
SwitchRes: [2560]x[ 496]_(60=59.996254Hz)
   rng(0): 2560 x 496_60.000000i 16.290000 [integ] scale(10, 2, 1) diff(0.00, 5.90, 0.0000) ratio(10.000, 2.214)
   rng(4): 2560 x 496_60.000000p 32.040000 [integ] scale(10, 2, 1) diff(0.00, 5.99, 0.0000) ratio(10.000, 2.214)
SwitchRes: [2560]x[ 512]_(60=60.001865Hz)
   rng(0): 2560 x 512_60.000000i 16.770000 [integ] scale(10, 2, 1) diff(0.00, 8.60, 0.0000) ratio(10.000, 2.286)
   rng(4): 2560 x 512_60.000000p 32.160000 [integ] scale(10, 2, 1) diff(0.00, 6.34, 0.0000) ratio(10.000, 2.286)
SwitchRes: [2560]x[ 544]_(60=59.755711Hz)
   rng(0): 2560 x 544_60.000000i 17.850000 [fract] scale(10, 2, 1) diff(0.00, 14.14, 0.0000) ratio(10.000, 2.429)
   rng(4): 2560 x 544_59.753956p 34.000001 [fract] scale(10, 2, 1) diff(0.00, 11.78, -0.2460) ratio(10.000, 2.429)
SwitchRes: [2560]x[ 560]_(58=58.121368Hz)
   rng(0): 2560 x 560_59.016392i 18.029508 [fract] scale(10, 2, 1) diff(0.00, 16.39, -0.9836) ratio(10.000, 2.500)
   rng(4): 2560 x 560_58.119659p 34.000001 [fract] scale(10, 2, 1) diff(0.00, 14.19, -1.8803) ratio(10.000, 2.500)
SwitchRes: [2560]x[ 600]_(60=60.000000Hz)
   rng(5): 2560 x 600_60.000000p 37.680000 [fract] scale(10, 2, 1) diff(0.00, 30.10, 0.0000) ratio(10.000, 2.679)
SwitchRes: [trackfld] (1) horizontal (256x224@60.000000)->(2560x240@60.000000)
SwitchRes: Modeline "2560x240_60 15.720000KHz 60.000000Hz" 51.184320 2560 2672 2912 3256 240 243 246 262   -hsync -vsync
Switchres: saving    ATI ADL timing "2560x240_60 15.718000KHz 59.992367Hz" 51.180000 2560 2672 2912 3256 240 243 246 262   -hsync -vsync
Switchres: updating  ATI ADL timing "2560x240_60 15.720000KHz 60.000000Hz" 51.184320 2560 2672 2912 3256 240 243 246 262   -hsync -vsync
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -autoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -nounevenstretch
SwitchRes: Setting option -unevenstretchx
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -nofilter
Video: Monitor 65537 = "\\.\DISPLAY1" (primary)
Direct3D: Using Direct3D 9Ex
Physical width 640, height 480
Direct3D: Initialize
Direct3D: Configuring adapter #0 = AMD Radeon HD 6700 Series
Direct3D: Adapter has Vendor ID: 1002 and Device ID: 68BA
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 16384x16384
Direct3D: Device created at 2560x240
Direct3D: First scanline: 19, Last scanline: 259, Break scanline: 259, Delay scanline: -7
Direct3D: Initialize HLSL
Direct3D: Unable to find D3DXCreateEffectFromFileW
RawInput: APIs detected
stream_buffer_size = 37888
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Input: Adding keyboard #0: Standard PS/2 Keyboard (device id: \\?\ACPI#PNP0303#4&20d7719e&0#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding keyboard #1: HID Keyboard Device (device id: \\?\HID#VID_0488&PID_00DF&Col01#6&2c2c297&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #0: HID-compliant mouse (device id: \\?\HID#VID_0488&PID_00DF&Col02#6&2c2c297&0&0001#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #0: HID-compliant mouse (device id: \\?\HID#VID_0488&PID_00DF&Col02#6&2c2c297&0&0001#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Region ':maincpu' created
unzip: opened archive file roms\trackfld.zip
unzip: found roms\trackfld.zip ECD
unzip: roms\trackfld.zip has no ZIP64 ECD locator
unzip: read roms\trackfld.zip central directory
unzip: closing archive file roms\trackfld.zip and sending to cache
unzip: found roms\trackfld.zip in cache
Region ':audiocpu' created
Region ':gfx1' created
Region ':gfx2' created
Region ':proms' created
Region ':vlm' created
Optional memory region ':nvram' not found
Optional memory region ':palette:finder_dummy_tag' not found
Starting Track & Field ':'
  (missing dependencies; rescheduling)
Starting KONAMI-1 ':maincpu'
Starting Z80 ':audiocpu'
Starting 74LS259 Addressable Latch ':mainlatch'
Starting NVRAM ':nvram'
Starting Watchdog Timer ':watchdog'
Starting Video Screen ':screen'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Starting Speaker ':speaker'
Starting Generic 8-bit latch ':soundlatch'
Starting Track And Field Audio ':trackfld_audio'
Starting 8-Bit R-2R DAC ':dac'
Starting Voltage Regulator ':vref'
Starting SN76496 ':snsnd'
Starting Sanyo VLM5030 ':vlm'
Average speed: 100.00% (1 seconds)
Switchres: restoring ATI ADL timing "2560x240_60 15.718000KHz 59.992367Hz" 51.180000 2560 2672 2912 3256 240 243 246 262   -hsync -vsync
ATI/AMD ADL close
Sound: buffer overflows=4 underflows=0
