Author Topic: What are the pins on Ultimarcs A-Pac for?  (Read 2250 times)
KonkeyKong
  • Last login:October 10, 2021, 09:57:07 pm
  • Monkey is my business and business is good.
« on: February 01, 2018, 09:02:59 pm »
there are 9 pins near the end of the board that i can't find any documentation on... ???
05SRT4
  • Check out my Pow Pow
Re: What are the pins on Ultimarcs A-Pac for?
« Reply #1 on: February 02, 2018, 02:08:14 am »
I always thought it was for the Console adapter.
https://www.ultimarc.com/console.html
The site says the A-Pac and I-pac boards are universal and the I-pac info states the following.
The I-PAC2 has 32 inputs. They are all programmable and are marked as 2 joysticks, 8 buttons each, plus coin1, coin2, start1, start2 and Mame control keys. Any inputs can be assigned as a shift key to access an alternate code set. This board also has a connector which can be configured to plug our trackball and spinner into, or for our console interfaces.
05SRT4
« Reply #2 on: February 02, 2018, 02:20:16 am »
But also this is on the site for the iPAC-4
Note the 9-pin header on the I-PAC 4 is for factory use only.
So maybe its nothing...
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: February 02, 2018, 02:23:34 am »
On the A-PAC these pins are only used by us to load firmware to the board and test.
5V and GND can be sourced from these if required though.
KonkeyKong
« Reply #4 on: February 02, 2018, 07:53:19 am »
That's exactly what i was hoping for!!! Could you please diagram or describe which pins to use?  Would it be enough to power 4 or 5 regular LEDs  ~5V or less each?
AndyWarne
    • Ultimarc
« Reply #5 on: February 02, 2018, 09:24:29 am »
This would power 5 LEDs without a problem.
« Reply #6 on: February 02, 2018, 09:44:32 am »
Andy, you are just the *best* .   Love your products and how well you support them, we need more peeps like you in the world.
Real picture of the bottom of my boot:
AndyWarne
    • Ultimarc
« Reply #7 on: February 02, 2018, 12:08:43 pm »
Crikey, immortalized! Hope you dont have any light colored carpets though :)
