Author Topic: Emulators for CRT monitor with super resolutions  (Read 3776 times)
haynor666
  • Last login:September 14, 2026, 03:38:01 pm
  • retro maniac
« on: January 28, 2018, 10:50:03 am »
I'm right now switching from old XP x32 with native resolutions to windows 7x64 with only super resolutions.
It's really sad but some of my emulators either does not work correctly or does not correctly switch into fullscreen and/or switch resolutions in the middle of emulation. More over some works and switch correctly cannot work in fullscreen using super resolutions (does not ignore aspect ratio but forcing ratio 1:1 or 4:3).
So now question is what emulators besides Mednafen and groovymame does work correctly with windows 7x64 and super resolutions?
Calamity
  • Moderator
  • Last login:September 24, 2026, 07:35:09 am
  • Quote me with care
Re: Emulators for CRT monitor with super resolutions
« Reply #1 on: January 28, 2018, 01:54:56 pm »
Nothing forces you to use super resolutions only. You can use super resolutions for GM/Mednafen and normal resolutions for the rest of emulators.
Steps to create a log:
haynor666
  • retro maniac
« Reply #2 on: January 28, 2018, 02:02:55 pm »
But I prefer to use super resolution because geometry for super resolution can be aligned better for super resolutions.
For example it's almost impossible to center nicely 256x240 but 2560x240 could be centered on TV almost perfect.
haynor666
  • retro maniac
« Reply #3 on: February 05, 2018, 05:45:17 pm »
Did some tests and only Mednafen so far works correctly with such resolutions. All other emus simply refuses to show picture on whole screen nicely :/
