Author Topic: Adding a spinner to bartop  (Read 5332 times)
PsychoHeadache
  • Last login:January 26, 2018, 02:05:24 pm
« on: January 25, 2018, 10:28:18 am »
Go easy on me, first post.
I have a bartop built, and so far pleased with the results.  I did things mostly on the cheap just to see how it all works and may upgrade buttons/joysticks in the future.  In any case, it's built, all working well except I find that certain games would work better with a spinner rather than a joystick(most driving games and things like breakout).  I see there appear to be a couple of choices for a spinner; Spintrak and Turbotwist.  Are those 2 basically the only option?  Further question then is I see they have a USB interface and they also seem to have a couple of button inputs as well, do those button inputs need to be hooked up?  I already have 2 USB zero delay inputs with the 6 button/joystick input working.  Does the spinner show up as a third control or can it be auxillary to one of the existing USB zero delay inputs?  I am worried that just buying the spinner, plugging it into a USB port on the R-Pi will result in a third input but then the buttons won't work in conjunction w/ the spinner.  Anyway, hoping someone can point me in the right direction on how this all can work.
Thank you!
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
Re: Adding a spinner to bartop
« Reply #1 on: January 25, 2018, 01:24:37 pm »
I would say you could use two buttons you use with the Zero delays could be wired to the spinner as well (so they will work for both the joystick/button combo and the spinner). Otherwise you can probably just setup the emulator (retroarch) to use the buttons from player 1/2 to work with the spinner (player 3) for several games.
I don't know for sure, but that's how I'm planning to setup my trackball.
Titchgamer
« Reply #2 on: January 25, 2018, 01:27:28 pm »
The spinners are basicly treated as single axis mice.
As for the buttons you can wire them if you wish but there is no need really just use your already wired buttons.
barrymossel
  • Spectrum
« Reply #3 on: January 25, 2018, 01:32:39 pm »
PsychoHeadache
« Reply #4 on: January 25, 2018, 04:06:09 pm »
Thanks for all the help.  All makes sense now.
