Author Topic: Zero Delay Arcade USB Encoderor I-Pac2  (Read 4205 times)
steved61
  • Last login:October 19, 2025, 01:05:53 pm
« on: January 17, 2018, 02:03:36 pm »
I have an I-Pac2 and Zero Delay Arcade USB Encoder. My control panel will have (3) Joystick's on the control panel ,which encoder is best for my needs ?
UEDan
  • Last login:November 10, 2019, 05:54:08 am
Re: Zero Delay Arcade USB Encoderor I-Pac2
« Reply #1 on: January 17, 2018, 07:14:14 pm »
How many buttons total? You may need an I-Pac 4.
Either way, I-Pac.
JDFan
« Reply #2 on: January 17, 2018, 09:28:38 pm »
3 joysticks and what else ? - will the joysticks all 3 be used at the same time in a game ? Figure each Joystick requires 4 inputs unless you are using 2 8 way joysticks and 1 4 way that will not be used at the same time that the 8 ways are being used in which case you could double up the inputs between 1 8 way and the 4 way - so the 3 joysticks would only use 8 inputs total.  :dunno
steved61
« Reply #3 on: January 18, 2018, 01:45:06 pm »
18 buttons total and the 4/8 way joysticks are both going to be joystick 1. No more then 2 joysticks will be used at the same time. Will I be able to use the extra features of the I-Pac2 ?  The I-Pac2 is about 3 times the price of the Zero Delay encoder.
If I can't use the extra features on the I-Pac2 I will save the I-Pac2 encoder for another project.
Thanks Guys.
SteveD61
UEDan
« Reply #4 on: January 18, 2018, 02:13:01 pm »
Sooo 26 inputs total. 30 if you give the 4 way dedicated inputs.
What features are you looking to use? Do you need a shift function?
Do you care if you have to reconfigure controls the if Zero Delay controllers swaps joystick IDs? ie stick #2 shows up as P1.
Is this just a control panel?
Which project will be the nicer project? Put the IPAC in there.
steved61
« Reply #5 on: January 18, 2018, 03:09:24 pm »
I"ll use the I-Pac2. Thanks for your
advice.
SteveD61
