Author Topic: GM menu scrambled/off sync.  (Read 3471 times)
waxtrax
  • Last login:March 04, 2018, 02:06:49 pm
« on: January 14, 2018, 04:57:12 pm »
First issue with GM after a couple of years.
Got back to a scrambled menu after being away from the cab. Computer and GM working and games load, I just don't see the menu, as it looks out of sync.
Anyone encountered this perticular problem? Guess the XP resolution is off. Question is why and how to fix it,
Help appreciated.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: GM menu scrambled/off sync.
« Reply #1 on: January 14, 2018, 11:01:02 pm »
Depending on what your screen is, check the sync pots on the monitor if they help...
maybe H-sync ?
waxtrax
« Reply #2 on: January 15, 2018, 12:08:25 pm »
Will def do but games play ok. So it's a bit  :dunno
waxtrax
« Reply #3 on: January 15, 2018, 03:49:31 pm »
Deffo something with an unsupported modeline triggered in the menu. Games play fine, all buttons work toggling the menus. I'll upload a picture.
« Last Edit: January 15, 2018, 03:54:29 pm by waxtrax »
buttersoft
  • Last login:Today at 02:21:06 am
  • Is running at 15kHz
« Reply #4 on: January 15, 2018, 06:19:24 pm »
Is this also the desktop resolution? I'd guess that windows has just grabbed some fallback setting somewhere. Try plugging an LCD in, and setup the desktop again?
Calamity
  • Moderator
  • Online Online
  • Last login:Today at 03:21:10 am
  • Quote me with care
« Reply #5 on: January 16, 2018, 11:22:01 am »
Not necessarily an unsupported resolution. As Sledge pointed out, H-sync pot may have modified its adjustment, even slightly, due to the cold, heat, an earthquake, whatever. This is probably the cause if you chose a resolution with high horizontal frequency for the desktop (typical case).
If that doesn't work, the boot ->F8->VGA mode, etc.
Steps to create a log:
waxtrax
« Reply #6 on: January 18, 2018, 05:36:00 am »
Connected an LCD but of course it doesn't load resolutions. "Not supported"
Connect back to CRT and won't load GM, just reboots.
waxtrax
« Reply #7 on: January 18, 2018, 03:30:43 pm »
Installed CRT Emudrivers again and ran WMaker. 120 modes..fine, hook it up to the cab. loads a while with flicker, reboots..again and again...sigh.
Think I might just take it as an oppurtunity to update the whole computer.  :-[
