Author Topic: iPac2, Ultimarc Sticks, 3" Imperial TB  (Read 2329 times)
pfriedel
  • Last login:April 07, 2004, 04:17:23 pm
« on: February 01, 2004, 01:00:43 pm »
2 iPac2 USB/PS2 (includes USB adaptor cable).  Older, but they work fine - I just finally upgraded to a single iPac4, so I can let these go. $30 each.
3" Imperial Trackball.  Has seen field use, but is in working condition.  Encoders work, comes with a spare set of bearings/rollers.  Only notable problem is that the bottom case is cracked, but it doesn't seem to affect gameplay, unless if you plan on slamming it in Golden Tee.  H. Betti sells replacement case bottoms (IMP 47-4305-04) for $2, if you find it to be a problem.  But as a standard Windows Pointing Device it works fine. (Needs a mouse hack, though.)  Not compatible with the no-bolts-showing mounting plates, but the 8 bolt style plate that Bob Roberts sells should work fine.  (The holes aren't big enough for the Happs studs.  Eh.) $30.
Older style Ultimarc T-Stik.  Black.  $10.
Older Style Ultimarc J-Stick.  Oval top.  Black.  Slight wear. $10.
eightbit
  • My cab is never done...
Re:iPac2, Ultimarc Sticks, 3" Imperial TB
« Reply #1 on: February 01, 2004, 06:48:49 pm »
FYI I recently mounted a imperial betson TB to a happs no bolts showing plate . You just have to drill the holes in the TB slightly larger.
pfriedel
« Reply #2 on: February 01, 2004, 10:57:33 pm »
Yeah, I figured it would be something as simple as that, which is actually kind of nice - this is the low-lip ball, and if I were to bother, I wouldn't have to use the spacing washers I'm using with my other TB.  Ah well, my loss, some buyer's gain. :)
pfriedel
« Reply #3 on: February 04, 2004, 02:30:39 pm »
iPacs and sticks are tentatively sold, Trackball still available.
LoRDDeVO
  • Last login:January 06, 2023, 01:27:54 pm
  • 80's retrotechnoelectrogeek
« Reply #4 on: February 04, 2004, 03:18:00 pm »
pmed ya about the trackball
