Author Topic: WG-25k7191 problems  (Read 1846 times)
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
WG-25k7191 problems
« on: February 01, 2004, 12:44:19 pm »
My monitor has died on me, and I'd like to fix it.  It's been working fine until the other day.  Here is what happened:
I had the monitor powered on for several days (I didn't realize that it was on).  It was showing a black screen for that time because a screen saver had kicked in.  I was far away in a another room when I suddenly heard a really loud screaming sound.  The monitor was making a somewhat high-pitched sound that sounded to me like electrical sparks.  I unplugged everything and it stopped.  I took the monitor out of my cabinet and turned out the lights so I could SEE what was happening, but when I powered it on again nothing happened - no video and no sounds.  I checked the fuse, and it is blown.
There was a pretty strong smell (?) that didn't leave the apartment for a few days.
It's probably a bad idea, but my first idea would be to replace the fuse so I can watch and see where the sparks are flying.
Any recommendations on how I should go about finding out what the problem is so I can fix it?
Thanks in advance,
Jake
Ken Layton
  • Guru
  • Technician
Re:WG-25k7191 problems
« Reply #1 on: February 01, 2004, 12:55:23 pm »
It sounds exactly like the flyback blew out. Zanen Electronics sells them for around 26 bucks  (phone 1-806-829-2780). You may also have a bad horizontal output transistor and/or capacitor C36 (critical safety cap). Those are all common failure items Bob Roberts stocks all those parts.
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #2 on: February 01, 2004, 01:58:32 pm »
Great, thanks.  I will replace them and see what happens.
menace
« Reply #3 on: February 02, 2004, 07:08:02 am »
bob roberts also has flybacks--$21.00.  If you are unsure of your HOT I have 2 here that we could compare readings on.
Just out of curiosity did you pop another fuse in to see what happened?  I have a chassis here that pops fuses and with the help of ken, the only thing that I haven't replaced is the flyback--wondered if you would get the same results (i.e. popping fuses)
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #4 on: February 02, 2004, 06:14:01 pm »
No I started playing with it yet - it may be a little while, but I'll post back here when i do.
