Author Topic: S-Video to composite Great Picture?? huh?  (Read 3591 times)
rurdy4me
« on: May 28, 2002, 08:42:56 pm »
Came across this website...says that their cable can produce as good of quality for composite tvs as svideo. That being the case, you could get a tv for alot less without the svideo input. Any ideas?
www.svideo.com
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
Re: S-Video to composite Great Picture?? huh?
« Reply #1 on: May 29, 2002, 11:40:16 am »
I would be sceptical... but it should be possible.
High end scan converters do a GREAT job on RCA... but they are 2-5 thousand...
The question is if anyone is able to produce a cheap solution.  It should be doable (since the prices of compenents go down).
I would hope that someone could do a scan converter that changes 640x480 > 320x240 x 15hz with antialiased data points... and handle 320x240@60hz to 320x240@15hz.  So you could use windows easily with a ArcadeCRT without using a weird video card.
  • Last login:June 07, 2026, 12:45:36 pm
« Reply #2 on: May 31, 2002, 01:50:23 am »
Ok I looked at the site... here's what I got from it.
Is it going to give you "near s-video quality" like it says?  Probably not.
Will it improve the quality of your display?
Believe it or not the answer is yes.  The fact that it keeps the signal in svid format until it reaches the end of the cable is going to cut down on signal degredation dramatically.  It will also help color bleeding a little.  Your overall sharpness in picture might or might not be affected.
Is the price right?
Yes again, only 16.99 for the standard cable.  (The rest of them are overpriced btw and kinda the same thing with audio out tacked on, which you don't need.)  Your going to pay about 10-20 bucks for a decent svid cable so that's pretty good.
Should you try it?
I don't think it's a big enough investment to have to worry about the loss of money.  I might pick one up to play with myself.
I hope that helps out some.
