Author Topic: So... I picked up my first machine today! *new discovery!!  (Read 9785 times)
krick
  • Gotta have blue hair.
Re:So... I picked up my first machine today! *new discovery!!
« Reply #40 on: February 03, 2004, 01:13:54 pm »
I went to that auction in Cherry Hill, NJ right before Christmas...picked up a U.N. Squadron game that works great and a Neo Geo that has no cartridge and has a broken monitor neck.  The Neo Geo cab only cost $30 and is gonna make an awesome MAME cabinet I think.  I plan on just sticking a computer monitor in mine.
Does your Neo-Geo cab have a 37" wide control panel?
How wide is the cabinet itself?
There were 2 Neo-Geo units at the last show.  One was a narrow unit with a standard control panel, the other a wide unit (29"?) with a 37" control panel.  Both went for quite a bit more than I expected.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Tiger-Heli
    • Tiger-Heli
« Reply #41 on: February 03, 2004, 01:17:55 pm »
Hi Sephroth,
Looks like you and Crapjoint could work out a deal . . . he has a 49-way cab and wants to convert it to 8-way.  You have an 8-way and want to convert it to 49-way.
Seems like you could just swap parts with each other.
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #42 on: February 03, 2004, 01:44:04 pm »
well i figured out the speaker problem, i looked in the manual that came with the cabinet, and in the pinout for the JAMMA connector pin 11 & M are positive and negative for right side speaker, well i look at the connector and theres no wires in those slots. sooo i guess all i have to do is run a wire from those pins to my speaker. im gonna use a stock 6x9 speaker i had in my car that i replaced, and ill probably switch the one in there with the matching car speaker since it looks old.
"Owens is the ringleader in the ass hat circus"  D K
