Author Topic: Freesync on VGA CRT  (Read 2511 times)
retrogamer123
  • Last login:April 11, 2021, 04:06:23 am
Freesync on VGA CRT
« on: December 11, 2017, 01:37:27 pm »
According to this page, freesync works on some vga crts ^^
https://forums.blurbusters.com/viewtopic.php?f=17&t=3234
https://forums.guru3d.com/threads/cru-custom-resolution-utility-tips-tricks-and-monitors-oc-lcd-led-crt.410187/
Its quite handy if that's the case. Since the Vesa Standard should go down to 56Hz, so at least, games that are in the 56-60fps range should run in their native speed without custom modelines then.
Maybe it is helpful for someone to tinker around with it, still haven't got a freesync card to test it.
