Author Topic: Looking for an amplifier  (Read 3803 times)
Willard_Bones
  • Last login:December 26, 2022, 06:06:33 pm
« on: December 09, 2017, 04:52:21 pm »
I need help finding an amplifier. I have an arcade cabinet with a twin system: Raspberry Pi and JROK.
The RPi has  stereo line-out sound.
The JROK outputs speaker-level mono.
I would like to have an amp that could output the JROK signal to two speakers. And have the RPi as a second source.
Ideally, switch automatically to whichever input is active.
The speakers are Polk Audio 5-inch automotive. I think amplifier output of 20 watts would be plenty.
What advice can you guys give me?
Sent from my iPad using Tapatalk
adgloride
  • Last login:October 16, 2018, 05:29:06 pm
Re: Looking for an amplifier
« Reply #1 on: December 18, 2017, 05:00:58 pm »
UEDan
  • Last login:November 10, 2019, 05:54:08 am
« Reply #2 on: December 29, 2017, 06:16:44 pm »
Ideally only 1 unit will ever be on at once right?
Cheap amp board:
https://www.amazon.com/DROK-TPA3116-Amplifier-Adjustment-Potentiometer/dp/B0177F614Y/ref=sr_1_13?ie=UTF8&qid=1514587762&sr=8-13&keywords=drok+audio+amplifier
JROK ouput, convert to line level:
https://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070&awkw=78572876905&awat=pla&awnw=s&awcr=50190041905&awdv=c&awug=9031546
or
Build your own:
http://www.epanorama.net/circuits/speaker_to_line.html
Then make a Y cable. Wire the JROK's mono to both L and R lines of the amp's input. And wire the rPi's out to the same amp's input.
Jenky... should work...
