Author Topic: Vertical cab setup, need help!  (Read 2465 times)
saiyan7702
  • Last login:January 06, 2018, 11:20:59 am
« on: December 08, 2017, 11:27:22 pm »
whats up guys new here and ive about ready to smash my face into the computer screen trying to setup a vertical cab. I downloaded hypertate and while windows is set to normal (landscape) mode hyperspin will boot and be vertical. ok great but when i launch a mame game its not vertical. Also i have Pinball FX i would like to be vertical as well. I would really appreciate some help here. thank you
loupg
  • Last login:December 26, 2021, 06:20:34 pm
Re: Vertical cab setup, need help!
« Reply #1 on: December 09, 2017, 09:51:42 pm »
I believe you want to edit your mame.ini file and set ror to 1 (should be 0 by default)
saiyan7702
« Reply #2 on: December 09, 2017, 10:43:45 pm »
tried it, works when you launch mame alone but not when hypertate lanches it
loupg
« Reply #3 on: December 10, 2017, 12:06:12 am »
I’m not actually very familiar with hypertate, but I’ve run into this before with other frontends that run mame as a user other than yourself.  There is likely a different mame.ini file somewhere you’ll need to edit.  Otherwise, if hypertate supports mame command line options, you can set it to add -ror when starting a rom.
saiyan7702
« Reply #4 on: December 10, 2017, 01:18:39 am »
hypertate is just hyperspin really, where do i add this -ror line
loupg
« Reply #5 on: December 10, 2017, 09:50:59 am »
I don’t use hyper spin either 😉
From what I can find: Under wheel settings, emulator, MAME, then the params block.
Don’t know if that’s correct, but it’s what I found in about 30 seconds of googling.
