Author Topic: 15khz kernel patches for 4.9.0-4-amd64  (Read 6941 times)
ZoOl007
  • Last login:August 02, 2020, 12:03:38 pm
    • RGBcommander
« on: December 06, 2017, 09:18:37 am »
Hi,
I have some free time and I'm dabbling around with crt's again...
I guess I'd ask here first so:
I can't find the 3 15khz kernel patches files for kernel 4.9.0-4-amd64
that is to say I have
1996 Dec  6 14:57 ati9200_pllfix-3.19.diff
5297 Dec  6 14:57 avga3000-4.4.diff
and I *think* those are the current ones but where can I find linux-4.9.diff?
I want to compile a custom kernel for debian9 for - later - GroovyMame
does anybody know where I can get the latest diffs please?
thank you.
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
Re: 15khz kernel patches for 4.9.0-4-amd64
« Reply #1 on: December 12, 2017, 02:27:58 am »
Hi,
You can find the latest diff here. They are working up to 14.4.x kernel version.
https://github.com/Ansa89/linux-15khz-patch
Cheers!
ZoOl007
    • RGBcommander
« Reply #2 on: January 14, 2018, 12:27:39 pm »
Thanks. I've only now had the time for it but I've got a kernel with 15khz patches  ;D... If only I could get groovymame running now  :dizzy:
Doozer
  • Z80 ERROR
« Reply #3 on: January 14, 2018, 01:05:16 pm »
Easy one, pick your desired version here  :  https://drive.google.com/drive/folders/0B5iMjDor3P__aEFpcVNkVW5jbEE
ZoOl007
    • RGBcommander
« Reply #4 on: January 14, 2018, 01:08:25 pm »
I did that first but it is compiled against an older qt version. I compiled my own but I have issues with it. I mean, the binary itself runs fine but I've got no gui on the crt... black screen.
« Last Edit: January 14, 2018, 01:10:50 pm by ZoOl007 »
Doozer
  • Z80 ERROR
« Reply #5 on: January 14, 2018, 02:19:55 pm »
What version of QT libs do you have on your system? The arch (latest) version are the following:
Code: [Select]
        libQt5Widgets.so.5 => /usr/lib/libQt5Widgets.so.5 (0x00007fb4743bf000)
        libQt5Gui.so.5 => /usr/lib/libQt5Gui.so.5 (0x00007fb473c00000)
        libQt5Core.so.5 => /usr/lib/libQt5Core.so.5 (0x00007fb4734fa000)
ZoOl007
    • RGBcommander
« Reply #6 on: January 15, 2018, 11:34:04 am »
I'm wrong. Yours is the, as of writing, very latest. Mine is older.
~$ dpkg -l | grep -m1 qt
ii  libqt5concurrent5:amd64               5.7.1+dfsg-3+b1                             amd64        Qt 5 concurrent module
EDIT : if you feel like it have a look at this post's last edits : http://forum.arcadecontrols.com/index.php/topic,156307.0.html
What would you try next?
« Last Edit: January 15, 2018, 02:50:56 pm by ZoOl007 »
Doozer
  • Z80 ERROR
« Reply #7 on: January 15, 2018, 03:17:22 pm »
[edit 4] as I understand it is just a matter of configuring the modeline inside mame.ini. What is your tvset or monitor model? Please post your mame.ini as well for verification.
