Author Topic: X-arcade issues  (Read 3053 times)
Scotty
  • Last login:May 01, 2025, 09:16:56 am
X-arcade issues
« on: December 04, 2017, 08:53:45 am »
OK, so I have had a Tankstick for years.  No issues.  Works great.   So I ordered a dual stick to use for the 4-way games (Pac-Man, Donkey Kong) etc....
Two issues.
1) At first I thought the left stick was not working.   Turns out, it is using the 4 arrow keys for directions.  The Tankstick uses keypad 2,4,6,8 for the directions for the left stick.   Why is this different?   Sure, I could create a new profile and correct it, or remap it in Mame, but why?  Why would they not be identical out of the box?
2)  As mentioned, I was gonna change these to 4-way sticks.  So I open it up and reverse the actuator and try it out, and it is just a little too short to make contact!!  It will touch the 4 switches, but not hard enough to trigger the switch.  Reverse it back to 8-way and all is fine.
HELP!!!!!!
« Last Edit: December 04, 2017, 08:56:25 am by Scotty »
woosdom
  • Last login:June 13, 2025, 06:14:45 pm
Re: X-arcade issues
« Reply #1 on: December 04, 2017, 05:02:33 pm »
1. I believe the older xarcade pcb’s were coded with the num buttons to control movement.  Their newer pcb versions use the direction keys.
2. You could bend the metal pins out a bit. That way the actuator will be touching them earlier and make the switch activate with the smaller side.
taylor34
  • Last login:December 05, 2017, 12:01:56 am
    • Game Room Info
Re: X-arcade issues
« Reply #2 on: December 04, 2017, 11:54:54 pm »
I always had issues with my tankstick suddenly forgetting it was numbers or arrow keys halfway through a game.  It's like the numlock key would inadvertently be getting pressed.  Because of that, I haven't used it much unfortunately.
woosdom
Re: X-arcade issues
« Reply #3 on: December 05, 2017, 08:37:21 am »
I switched the interface out with xin-mo ones on both of my xarcade joysticks.  I got them both cheap but really like them. They can handle a lot of abuse.
Re: X-arcade issues
« Reply #4 on: December 05, 2017, 01:09:28 pm »
In order to convert to true 4-way, I'd swap out the joystick.
You could simply grab this from GGG  but that would require that you have a genuine Happ Super joystick that has the two holes for the screws to mount the restrictor:  http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=71&products_id=310
Unfortunately, XArcade uses Happ Super knockoffs, so the bolt holes aren't there.
My suggestion:  Buy a nice ball top 4-way and pop it in there.  It needs to have the HAPP or IL bolt pattern (don't buy Sanwa or Seimitsu, they will not fit).
Have a look here and make sure you pick the ones that are 4-way and for wood panels:  http://www.tornadoterrys.com/surplus.htm
Good luck!
DeL
GeoMan
  • Last login:Yesterday at 11:58:49 am
Re: X-arcade issues
« Reply #5 on: December 07, 2017, 02:18:53 pm »
Replace X-Arcade's sticks with Ultrasticks 360 - you can program them as you want: 2-way, 4-way, 4-way diagonal, 8-way, analog,...
