Author Topic: Steering wheel in MAME  (Read 6305 times)
LoRDDeVO
  • Last login:January 06, 2023, 01:27:54 pm
  • 80's retrotechnoelectrogeek
« on: January 31, 2004, 02:53:56 pm »
www.tigersurplus.com is selling Logitech Wingman Formula GP Wheel +Pedal Set for 18.50. I bought 2 but I was wondering how to incorporate them in mame. They are usb is there anything I need to do to get them to work?? Thank you very much for your help
crashwg
Re:Steering wheel in MAME
« Reply #1 on: January 31, 2004, 02:55:54 pm »
Just set them up in windows to work, then use them in mame as analog joystics.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
LoRDDeVO
« Reply #2 on: January 31, 2004, 02:58:27 pm »
thank you crashwg I will try that
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« Reply #3 on: February 02, 2004, 10:21:57 am »
I bought the regular sidewinder wheel. Installed it and it works fine. Just add the "Joystick     1" to the mame.ini file. It works good however you must set up the wheel in each driving game for the first time.
Also, you need to adjust the sensitivity for each game. Doesnt take too long. Pole position works good... :) I have to work on the settings for Turbo. However I cannot get my Cruising to work. I dunno. It runs way to slow even after messing with framerates.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: February 02, 2004, 12:54:32 pm »
Chirsindfw, Cruising needs about a 4Ghz machine to work correctly.  The closest fix is enabling cheat mode and underclocking CPU 1 AFTER the initial CPU testing phase.
Sadly, the N64 port even has problems under Project 64, etc.
LordDevo - How much does Tigersurplus charge for shipping?
  • Last login:Yesterday at 01:02:42 am
« Reply #5 on: February 02, 2004, 01:05:04 pm »
Crusin probably won't even run properly on a 4 gig processor.  The sound chip is THAT intensive.
LoRDDeVO
« Reply #6 on: February 02, 2004, 01:09:49 pm »
$8.20 for ground... Its not bad the cheapest I found the wheel on the web was 30.00 and like 4.00 for shipping
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: February 02, 2004, 01:17:17 pm »
Pricewatch now shows it for $24.99 shipped, I just didn't notice that package2you.com is the same as tigersurplus.
The brick&mortar circuit city wants $39.99 for it, but I might go there and see it in person before deciding.
Thanks!!!
vishwats
  • Last login:August 10, 2004, 08:43:43 pm
  • No! Iam an Alpaca
    • Vishwa.net
« Reply #8 on: February 02, 2004, 03:48:48 pm »
Check this out,
http://store.yahoo.com/justdeals/logwmforgp.html
It is only $7.88 + 12.90 shipping
-VIshwa
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: February 02, 2004, 03:57:52 pm »
Check this out,
-VIshwa
Saw that also, but it's reconditioned, not new, FWIW
jerryjanis
  • Last login:September 10, 2026, 01:23:41 pm
  • Skate or Die!!!
    • Jake's Joystick
« Reply #10 on: February 02, 2004, 06:19:52 pm »
Check this out,
-VIshwa
Also if you add it to your shopping cart, it's not in stock so you can't order it (A lot of items on that site are like that)... ???
« Last Edit: February 02, 2004, 06:20:28 pm by jerryjanis »
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« Reply #11 on: February 03, 2004, 10:28:08 am »
Another good option is the 10buck RS wheel from Act-labs.
Good looking and great little wheel with pedals.  Shipping was 15 bucks btw.
Last... I got it working on a PC with the playstation default pluging -> converter -> PC and it works great.  And to my dreamcast through the dreamcast specific plugin... I couldn't find the direct PC cartridge anywhere (there was 1 I bought on ebay that wasn't for a game card... but a very specialized version that is completely outdated and impossible to find).... So go with the PS -> PC usb connector.
LoRDDeVO
« Reply #12 on: February 03, 2004, 11:10:52 am »
Check this out,
Dude thats also only the Wheel,  Tigersurplus has the wheel and the pedals for 18.50
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: February 03, 2004, 11:22:15 am »
Check this out,
Justdeals has the pedals as well, but it is re-conditioned.
