Author Topic: J-Pac and 15Khz old monitor  (Read 1798 times)
FlebusCroqus
  • Last login:November 17, 2017, 11:16:37 am
« on: November 17, 2017, 10:58:37 am »
Hello all!
I installed my pc on my old arcade monitor (KGR-1909) with Radeon HD 7700 and J-PAC and I use CRT-Emudrivers or soft-15khz for the 15Khz signal.
The orange and green sync lights of the J-Pac work, the monitor turns on but I only have a gray / blue image that appears. No windows desktop.
Also when I plug the J-Pac into the USB, the light flash test 45 times and goes off. In the Troubleshooting section of the J-Pac errors go up to 34 times.
Someone already had that kind of problem.
Spec:
Windows 7 64-bit
Radeon HD 7700
CRT-Emudriver Gold Soft-15Khz
J-Pac Usb powered
Thank you
