Author Topic: Volume echo on all games  (Read 3747 times)
Huskerfan
  • Last login:October 05, 2021, 11:40:38 pm
« on: October 28, 2017, 04:22:27 pm »
I'm using Mame64 or mameuifx32.
I have 4 gb ram, on a AMD Athlon dual core processor, 5000+ 2.6 GHz running Windows 10 and just the onboard audio card
I have my audio settings at 11000 and 5/5.  If I set them any higher the problem gets worse.
The sound echo's on every game.  Think of a public address announcer. :)
And the video is a little slow too but works at least.
Is my computer just weak sauce?  or is there something else I can try?
Gary
lovespicyfood
  • Last login:December 03, 2019, 12:37:08 am
Re: Volume echo on all games
« Reply #1 on: October 28, 2017, 05:40:12 pm »
Not sure if this will help, but I recently had a bit of the same issue, the sound just seemed a bit off.  Turns out I was using the TV speakers on my display panel AND the speakers built into my arcade cab.  Turned the TV speakers off and now it sounds GREAT!   ;D
Haze
    • MAME Development Blog
« Reply #2 on: October 28, 2017, 08:10:11 pm »
Gary
It's not a very good PC (AMD and many generations behind) but it should run some stuff.
If the video is slow the sound will echo, that is expected, because it isn't running at full speed.
Probably just need to install DirectX9 properly, and the video drivers for your card / onboard chipset.
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« Reply #3 on: October 29, 2017, 07:51:54 am »
I'd also check your audio driver isn't set to using some weird 'sound scheme', like 'festival' or some such.
Huskerfan
« Reply #4 on: October 29, 2017, 02:00:00 pm »
Thanks guys.  I'll try those suggestions.
Ian
  • Last login:February 27, 2026, 11:36:05 pm
« Reply #5 on: October 29, 2017, 04:50:50 pm »
I have echo in all of my street fighter games... nothing else... crazy right?  :banghead:
fallacy
  • Last login:February 19, 2026, 07:24:28 pm
« Reply #6 on: October 29, 2017, 07:27:05 pm »
go to your sound panel in windows, make sure the right output is set to default and disable everything else.
Huskerfan
« Reply #7 on: October 30, 2017, 02:15:48 pm »
Ok, I did some more testing.
The sound does not stutter when I play youtube videos or fox sports or espn sports and the video is just fine as well.
Only in game.
Hmmm, I'm bewildered.
Huskerfan
« Reply #8 on: October 30, 2017, 05:45:31 pm »
UPDATE:
I went into the mame settings "advanced" and changed frame skipping to "automatic" and all games work now except Golden Tee Fore 2006.  But I realize that's a drag on the pc so I understand.
