Author Topic: Eliminate arcade power supply for monitor?  (Read 4300 times)
keilmillerjr
  • Web Developer.
« on: October 18, 2017, 06:50:37 am »
I have a neo geo mvs that has been converted to mame. Don't shame me as everything is reversible and mame is done right. See .
I am using an ecostrip and a wells Gardner k7000.
Currently the only things that run off the mvs (atx style) arcade power supply is the monitor, fluorescent marquee light, and coin door reject lights. Is it safe to remove the power supply and wire the monitors isolation transformer directly to the ecostrip?
The real bob Roberts has an example using a filter and arcade power supply that likely has adjustable voltage. K7000 is 120vac +10% -15%. Should I be using a filter? Do I need voltage regulated?
lilshawn
  • Last login:May 30, 2026, 07:21:17 pm
Re: Eliminate arcade power supply for monitor?
« Reply #1 on: October 18, 2017, 12:44:51 pm »
no. the k7000 must be isolated with a 1:1 transformer. it should already be in the cabinet. you can remove everything else and power your board with an SMPS style power supply and your lights and stuff off straight mains... but you must retain the isolation for the monitor or it will blow up as soon as it's powered.
keilmillerjr
  • Web Developer.
« Reply #2 on: October 18, 2017, 12:48:51 pm »
I didn't ask about removing the isolation transformer. I know that.
lilshawn
« Reply #3 on: October 18, 2017, 01:03:35 pm »
as long as you retain the isolation for the monitor you can power the transformer any way you like... extension cord, power strip, relay, generator...
wire everything with plugs (fluorescent light, monitor, power supply for low voltage lighting if you have one) and plug them all into the slaves. Then plug your computer into the master. done.
the power stip might already have proper surge filtering... i'm not a fan of the switch circuit breaker format companys use... it is often the only protection... you can just buy a plug in model and use that into the first slave port...
https://www.amazon.com/360-Electrical-36083-1-Outlet-Protector/dp/B002Z7EDCC/ref=sr_1_12?s=hi&ie=UTF8&qid=1508346002&sr=1-12&keywords=plug+in+surge
nothing even needs to be plugged into it if you don't want. (the way the surge suppressor caps are wired it doesn't make a lick of difference as long as it's near the device intended to protect.) You don't need one for every port.
keilmillerjr
  • Web Developer.
« Reply #4 on: October 18, 2017, 01:55:44 pm »
Thank you. Questions answered. :)
