Author Topic: What is the best way to mount a bezel?  (Read 3756 times)
Jakobud
  • Last login:Today at 02:04:14 am
« on: October 15, 2017, 11:23:30 pm »
I have this kind of setup with a suspended LCD in the middle:
What is the best way to do a bezel here? I was going to make and order a bezel from GameOn Grafix. I was planning on a layer of plexi in front of the bezel. Do I need to put wood behind the plexi on the inside of the cabinet order to keep it from falling back into the cabinet on the sides? How do people typically secure the plexi in place too?
« Last Edit: October 15, 2017, 11:25:23 pm by Jakobud »
  • Last login:May 19, 2026, 11:21:47 am
Re: What is the best way to mount a bezel?
« Reply #1 on: October 15, 2017, 11:48:18 pm »
I’ve used a piece of 1/4 board with great results.
Jakobud
« Reply #2 on: October 16, 2017, 12:14:08 am »
So 1/4 plywood surrounding the entire monitor and then bezel directly on top of that?
I guess it would be nice for the bezel and plexi/glass to be as close to the screen as possible instead of adding 1/4 inch in there.
« Last Edit: October 16, 2017, 12:18:18 am by Jakobud »
« Reply #3 on: October 16, 2017, 12:22:09 am »
Make the monitor fit inside the 1/4" wood.  ::)
Jakobud
« Reply #4 on: October 16, 2017, 12:44:12 am »
Ah I see what you are saying. Okay gotcha thanks
« Reply #5 on: October 16, 2017, 12:40:50 pm »
Titchgamer
« Reply #6 on: October 16, 2017, 01:38:23 pm »
Looks like you could do with a bigger monitor in there??
« Reply #7 on: October 16, 2017, 02:11:39 pm »
I'm guessing he wants 4:3, and 20.1" is the biggest I can readily find, too...
« Reply #8 on: October 16, 2017, 02:27:02 pm »
Yes. You’re not going to notice 1/4 inch. If you do, you’re too anal retentive for this hobby. ;)
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« Reply #9 on: October 16, 2017, 04:41:36 pm »
I can't see the pic, for some reason.
