Author Topic: Question about range settings  (Read 3696 times)
zoopster
  • Last login:January 07, 2024, 10:54:12 am
« on: October 13, 2017, 05:04:15 pm »
I'm using the following modeline settings:
crt_range0                15200-20500, 54.70-62.00, 1.500, 4.700, 4.700, 0.602, 0.191, 1.352, 0, 0, 192, 288, 390, 576
crt_range1                30300-35000, 54.70-62.00, 0.500, 2.000, 2.600, 0.128, 0.030, 1.032, 0, 0, 320, 480, 0, 0
crt_range2                30300-35000, 54.70-62.00, 0.500, 2.000, 2.600, 0.030, 0.030, 1.032, 0, 0, 481, 512, 0, 0
crt_range3                42200-49900, 54.70-62.00, 0.800, 0.755, 3.400, 0.067, 0.156, 0.444, 0, 0, 640, 800, 0, 0
My CRT BVM monitor displays 15200-20500 and 42200-49900 perfectly but 30300-35000 has discoloration (solid image but muddy colors). I tried editing some of the modes manually to via arcadeOSD and have attempted to push the Horizontal sync up to 35-36khz which in one mode fixed the colors. But I have no idea what I'm actually doing!
If there a way I can remove the 30300-35000 range and will GroovyMame then use the 42200-49900 range instead for say 640x480p? Or how would I configure 640x480p to use the higher horizontal range?
John
zoopster
Re: Question about range settings
« Reply #1 on: October 14, 2017, 11:57:24 am »
Quick update. I change the mame.ini settings to:
crt_range1                42200-49900, 54.70-62.00, 0.500, 2.000, 2.600, 0.128, 0.030, 1.032, 0, 0, 320, 480, 0, 0
crt_range2                42200-49900, 54.70-62.00, 0.500, 2.000, 2.600, 0.030, 0.030, 1.032, 0, 0, 481, 512, 0, 0
That fixed the muddy color issue for Midday games but not 640x480p games. The Midday mode selected was 2560x400p image was rock solid and colors spot on but the V size alignment was squashed.
Calamity
  • Moderator
  • Last login:June 10, 2026, 02:56:33 am
  • Quote me with care
« Reply #2 on: October 15, 2017, 10:59:23 am »
You may try replacing the horizontal values, sometimes you get wrong colors when porch values are too low.
E.g., change:
by
30300-35000, 54.70-62.00,  0.800, 0.755, 3.400, 0.128, 0.030, 1.032, 0, 0, 320, 480, 0, 0
Steps to create a log:
zoopster
« Reply #3 on: October 21, 2017, 05:25:30 am »
Thanks Calamity for taking the time to respond. I managed to fix the colour issue in the end by trying out different ranges for the monitor file. My current settings in mame ini are:
crt_range1                42200-49900, 54.70-62.00, 0.500, 2.000, 2.600, 0.128, 0.030, 1.032, 0, 0, 320, 460, 0, 0
This provides good coverage across R-Type; Narc / Paperboy and Radikal Racers. The progressive mode for Narc, Paperboy and Radikal Racers is a bit squashed but with the v-size setting on the BVM D24 monitor maxed out it looks pretty good.
John
zoopster
« Reply #4 on: October 21, 2017, 03:29:50 pm »
To close the loop on the thread. I managed to tune most the video modes to get rid of the muddy colours by increasing the horizontal settings using ArcadeOSD. I then used ini files to set specific modes for games like Narc and Paperboy. Really pleased with the results.
