Author Topic: Rowe CD 100A  (Read 3583 times)
DaveN
  • Last login:August 12, 2023, 12:26:17 pm
Rowe CD 100A
« on: October 08, 2017, 05:36:53 pm »
I'm new here so I hope this post is OK. I have a Rowe CD100A Jukebox it was playing fine and then the sound went down real low and was distorted. Pulled the amp and all 4 8 amp fuses were bad.
What would cause this to just happen??
Thanks   Dave
Ken Layton
  • Guru
  • Technician
Re: Rowe CD 100A
« Reply #1 on: October 08, 2017, 10:50:46 pm »
Sounds like all four of the output transistors are bad. Did you have any external speakers connected to the jukebox?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe CD 100A
« Reply #2 on: October 09, 2017, 09:15:00 am »
Hi Dave,
I agree with Ken, it sounds as if you have overloaded the four outut transistors, if you have a transistor checker then take the transistors out one at a time and check them.
Regards
Alan
Alan Hood
ami-man
UK
DaveN
Re: Rowe CD 100A
« Reply #3 on: October 09, 2017, 10:25:45 am »
No extra speaker it was playing and just lost the sound
ami-man
Re: Rowe CD 100A
« Reply #4 on: October 10, 2017, 09:41:24 am »
Hi Dave,
Replace the four fuses with 5 amp fuses, if they blow again you will have to send your amplifier to a Rowe Ami specialist for testing/repair.
Regards
Alan
Alan Hood
ami-man
UK
DaveN
Re: Rowe CD 100A
« Reply #5 on: October 30, 2017, 01:47:32 pm »
 You are correct the output are bad and one driver test bad also.
Thank You for your help
