Author Topic: Anyone add jamma to a MAME cabinet  (Read 5751 times)
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
« on: September 30, 2017, 04:39:36 pm »
Yea I know, why add a jamma set up if you have MAME running.
To be more specific, I want to add a Soul Calabur II pcb to a MAME cab. It was one of my favorite games and I would like to be able to play a decent version of it.
How are folks doing this in regards to wiring?  :dunno Should I just solder the jamma wires to the disconnects?  I really don't want to cut all the disconnects off and twist the jamma wires on then put on new disconnects. :dizzy:
They treated me like an animal and that's what I became.
Titchgamer
Re: Anyone add jamma to a MAME cabinet
« Reply #1 on: September 30, 2017, 06:45:13 pm »
You need to provide more info really.
Whats your current setup?
keilmillerjr
  • Web Developer.
« Reply #2 on: September 30, 2017, 08:29:19 pm »
Use a jamma switcher.
PC -> JPAC -> SWITCH -> JAMMA HARNESS
PCB -> SWITCH -> JAMMA HARNESS
Something like that.
paigeoliver
  • Awesome face!
« Reply #3 on: September 30, 2017, 08:46:26 pm »
Most important question here really is what are you using for a monitor.
keilmillerjr
  • Web Developer.
« Reply #4 on: September 30, 2017, 08:54:42 pm »
I assumed crt since soul caliber 2 pcb uses a pc with a jpac like device to connect to jamma and crt. I hope I'm not making an @ss out of you and me.
« Reply #5 on: September 30, 2017, 09:01:42 pm »
I always say people should wire up their MAME machines to JAMMA.
It can help keep your wiring standard for when you want to upgrade or change it later. Plus it’s good for reselling if it comes to that.
Though with that being said, JAMMA switchers can be expensive if you plan on using them. But they’re the easiest way of getting a switcher installed, if your cabinet is already setup for JAMMA.
A cheaper option is to use relays on your existing wiring. Chopperthedog has done this before and it’s the most cost effective way of switching, but it’s a lot more work: http://forum.arcadecontrols.com/index.php/topic,130607.0.html
« Last Edit: September 30, 2017, 09:03:15 pm by opt2not »
rackoon
  • I EAT PENCILS!
« Reply #6 on: September 30, 2017, 10:32:47 pm »
my set up is three jfl8's- two are eight ways with 8 ultralux buttons and one is a four way with two buttons
I also have a trackball and a spinner
monitor is a 32" dual sink lcd using hdmi
and finally its all hooked up to a ipac ultimate ;D
the control panel is a copy made from the file knieval sent me / ever seen the neon cab/ it that but green :cheers:
paigeoliver
  • Awesome face!
« Reply #7 on: September 30, 2017, 11:59:33 pm »
I don't know what a dual sink is, but since Jamma boards don't just hook up to TV sets you have more problems than wiring.
rackoon
  • I EAT PENCILS!
« Reply #8 on: October 01, 2017, 02:17:39 am »
Whoops! I wanted to type dual sync, It works analog and digital. I guess that doesn't mean much anymore. But it does have vga and hdmi hook ups. :P
  • Last login:May 19, 2026, 11:21:47 am
« Reply #9 on: October 01, 2017, 01:39:12 pm »
You’re going to need a separate card to convert the signal to use with an LCD.
rackoon
  • I EAT PENCILS!
« Reply #10 on: October 02, 2017, 10:51:25 pm »
Ok i think I know what you mean. Are you talking about a cga to vga card :dunno
paigeoliver
  • Awesome face!
« Reply #11 on: October 02, 2017, 10:52:33 pm »
Honestly, you are better off getting a second cabinet than you are trying to do what you want to do there.
« Reply #12 on: October 03, 2017, 12:40:26 am »
Or just sell me that SCII.  >:D
rackoon
  • I EAT PENCILS!
« Reply #13 on: October 04, 2017, 10:23:37 pm »
No room for a second cab. This thing in a inner city high school algebra classroom. I have been turning on all the youngsters to retro gaming :notworthy:
I have a feeling I am going to end up soldering the jamma harness to the surface of the female disconnects
paigeoliver
  • Awesome face!
« Reply #14 on: October 08, 2017, 11:45:52 pm »
School lets you bring in pirated video games? That is certainly strange.
  • Last login:June 15, 2026, 07:01:25 pm
« Reply #15 on: October 09, 2017, 07:16:15 am »
That ship sailed a long time ago. If Amazon sells the stuff, a school classroom should be okay. ::)
1500points
  • Last login:November 20, 2018, 01:44:12 pm
    • How to succeed at Robotron
« Reply #16 on: October 09, 2017, 08:27:20 am »
I toy with so many different topics and games in my mame cab that I love having it jamma wired.
For MAME I use a J-pac to a laptop.
I used to have a normal LCD which meant I kept a gonbes cga to vga card in the cab.
Then I switched to a Wells-Gardner 19inch arcade flat panel that has inputs for both CGA and VGA, and converts the signal internally.
Now it is no biggie to run an FPGA in cga video out mode, or even real pcbs like Pacman and Galaxian using a jamma edge connector.
« Reply #17 on: October 09, 2017, 08:35:18 am »
So we're all pretending that Namco System 246 cant output a 31 kHz (VGA) signal right?
rackoon
  • I EAT PENCILS!
« Reply #18 on: October 14, 2017, 01:09:26 pm »
I am kinda shock about this. I assumed that every one was doing this and  I was just to lazy to get around to it, :dizzy:
Here is a funny note about having these games in my classroom, I have had the mayor, a congressman. two superintendents, and all of them shook my hand and thanked me for building such a neat project with troubled youth. No one ever thought about where the games came from :dunno
« Reply #19 on: October 16, 2017, 11:55:54 am »
you could just emulate the gamecube or PS2 version?
