Author Topic: DemulShooter help needed please  (Read 3124 times)
iandsm1
  • Last login:January 09, 2019, 02:04:54 pm
« on: September 25, 2017, 07:06:09 am »
Hi there, I would like to ask for some assistance please, I'm a little confused on how to use DemulShooter, I wish to use this with teknoparrot and sega golden gun, as the game loads but will not pick up any controls inputed from my xbox 360 controller in settings on teknoparrot, I came across this page while looking for a solution :) and have downloaded demulshooter 6.8 and have set the p1 controls as xbox 360 through the gui demulshooter.exe and saved, now the confusion is how do I use the commands such as "demulshooter.exe -target=ringwide -rom=lgi" I have no idea on what I should do, or where to input this information to get this to work correctly, please any help will be greatly appreciated
thet0ast3r
  • Last login:October 26, 2020, 02:10:37 pm
  • Chihiro ftw
Re: DemulShooter help needed please
« Reply #1 on: September 26, 2017, 05:56:41 pm »
For the exact commands you have to put to make the specific games work, please refer to the  README.txt that comes with DemulShooter.
You extract DemulShooter somewhere ( e.g. program files), open the app like you most likely did, configure your settings and close the app.
Then you open a cmd window, change the directory to where the DemulShooter.exe is located, and run Demulshooter with typing the command:
DemulShooter.exe -target=ttx -rom=mgungun2
You`ll have to swap out the ttx and mgungun2 for the ones needed for your game -> take a look at the ini.
If you pressed enter, "nothing" should happen, but you`ll see DemulShooter.exe running in the taskmanager.
Then just go ahead and launch the game you just stated in the demulshooter command. Make sure there are no spaces in the commands, else it won`t work.
have fun
thet0ast3r
