Author Topic: Mamehooker issue with key output  (Read 2286 times)
Marcoqwerty
  • Last login:January 04, 2026, 06:20:39 pm
« on: September 24, 2017, 03:50:29 pm »
Problem:
Cant catch the output when press V key
Setup:
i get this issue after setup Mamehooker in this way
Default.ini (launch a cicle of light and interrupt them when start MAME)
Code: [Select]
[General]
MameHookerStart=
MameHookerStop=
MameStart=kls 1,rfs HyperspinAllOFF 1 %s%
MameStop=lfs HyperspinLuciON 1 %s%
StateChange=
OnPause=
OnRotate=
[KeyStates]
RefreshTime=
[Output]
SpyHunter.ini (map some output and the V for light and rumble when press fire)
Code: [Select]
[General]
MameStart=
MameStop=
StateChange=
OnRotate=
OnPause=
[KeyStates]
RefreshTime=
v=rfs smartasd 0 %s%09,rfs smartasd 0 %s%04,rfs smartasd 0 %s%07
[Output]
lamp2=rfs smartasd 0 %s%13
lamp3=rfs smartasd 0 %s%08
lamp0=rfs smartasd 0 %s%08
lamp4=
lamp1=rfs smartasd 0 %s%08
Result:
All the output light working correctly except for the V no output grabbed
Weird thing:
If,during the game, i open Mamehooker and open SPYHUNTER.ini.....AND ONLY SAVE.....ONLY SAVE without touch anything....the ini works correcly and catch the V key
« Last Edit: September 24, 2017, 03:52:42 pm by Marcoqwerty »
