Author Topic: Using Aimtrak w/ Multiple IR bars/sources?  (Read 3209 times)
USSCrazybat
  • Last login:February 26, 2023, 09:33:28 am
  • I can't build controls for s**t!
« on: August 10, 2017, 05:44:36 pm »
Hello!
As I'm trying to get back to my own Aimtrak project I'm curious - I understand that the only thing in the IR/sensor bars are the lights - any IR pointer device will do all the detecting/computing/positioning themselves. On the topic of better improving accuracy from multiple angles, is the Aimtrak software able to interpret more than one IR bar/source and if so does it have any effect on accuracy?
Titchgamer
Re: Using Aimtrak w/ Multiple IR bars/sources?
« Reply #1 on: August 11, 2017, 07:42:40 am »
Its my understanding that it only reads from the one bar.
If you do try multiple bars though I would be interested to see your results as I considered the same thing myself.
I found the best ways of increasing the accuracy though was dependant on the height/angle that the bar was mounted and the amount of ambient light.
They dont like lots of ambient light or reflective surfaces like big windows, mirrors etc.
dougan78
  • Last login:January 21, 2023, 10:19:44 pm
« Reply #2 on: August 11, 2017, 05:28:39 pm »
If you have a larger screen, I have a 55", I had to get the super ir bar instead of the smaller one.  The distance from the screen matters as well.  Good luck.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: August 13, 2017, 02:28:27 pm »
The firmware in the Aimtrak reads the LEDs in the bar and is designed to use exactly this configuration only. Adding additional light sources will cause it not to work.
