Author Topic: Unable to update groovymame from LXDE  (Read 2466 times)
Edglaf
  • Last login:April 23, 2024, 03:38:27 am
« on: August 07, 2017, 04:11:20 am »
In Groovyarcade, using the LXDE frontend to update groovymame and move rom files, for some reason, wheever I try to replace /usr/local/binaries/groovymame file I get the message "permission denied". It does not allow me to change permissions to for that folder either. How can I easily do it? I'm not very skillful with linux so I do not know how to do it from a command line console...
Help, please!
cgrisamore
  • Last login:October 20, 2025, 05:02:11 pm
Re: Unable to update groovymame from LXDE
« Reply #1 on: August 07, 2017, 11:14:25 am »
Linux manages permissions depending on who the owner of the file is.  You can find out the owner and the current permissions by typing the below command in a terminal.
ls -l /path/to/file
You can use sudo command to temporarily give yourself root privileges to delete, replace, change owner, and/or change rights.
Edglaf
« Reply #2 on: August 08, 2017, 03:00:45 am »
Thanks, indeed it worked but could not remove the file at first. I just had not noticed that you have to set, preferably prior to installation, a password for root. I case it someone might need ir in the future:
From LXDE desktop open an LXterminal window, for example, and introduce these commands (roughly, i'm recalling from memmory):
Su –
#Introduce your password for root
Ls /usr/local/bin
Rm groovymame
