Author Topic: GroovyMAME: No Video Shows At All  (Read 3403 times)
markran
  • Last login:October 23, 2025, 10:14:47 pm
« on: August 06, 2017, 09:38:21 pm »
I'm trying to upgrade our much beloved 10 year-old MAME cab from .120 to current vintage. The cab has a ArcadeVGA2 (the ATI 9250 flavor) and a Wells Gardner D9200 CRT attached to a 3.1Ghz P4 with 1gb of RAM running WinXP 32. I installed GroovyMAME with new roms and am trying to run it from the command line to test. VMMMaker created 27 modelines and Arcade_OSD appears to be working from the Windows desktop. I'm running the Windows desktop in 800x600.
GroovyMAME runs but displays only a blank (black) screen. No pixels of any kind. Strangely the ROMs seem to be working despite not being visible. If I call a ROM like "GroovyMAME.exe joust" the screen goes blank but if I wait and then give it a coin and press 1Player, the game seems to start but the sound (which is the only detectable output) is messed up, too fast/too high pitch. It will exit when I press Esc. The command line window says "GroovyMAME.exe [joust] 292 x 240@60 -> 320 x 240@60"
Any thoughts as to what I should try or what diagnostic info I can provide?
EDIT TO ADD: I tried running stock MAME .187 from the command line and it appears to work fine. I see the UI and can select/run games. So the issue appears to be unique to GroovyMAME.
« Last Edit: August 06, 2017, 09:56:20 pm by markran »
markran
Re: GroovyMAME: No Video Shows At All
« Reply #1 on: August 07, 2017, 12:32:07 am »
Troubleshooting thoughts:
* Do "Super Resolutions" work with cards as old as the ATI 9250 / ArcadeVGA 2?
* Is there a setting to disable SwitchRes?
krick
  • Gotta have blue hair.
« Reply #2 on: August 07, 2017, 12:34:13 am »
Steps to create a log:
 - Attach resulting romname.txt file to your post, instead or pasting it.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
markran
« Reply #3 on: August 07, 2017, 01:57:23 am »
Thanks for your response. The file is attached.
Also, some experimental info. I tried setting full-screen off and I can see the window GroovyMAME creates, there's just black inside it though.
« Last Edit: August 07, 2017, 02:00:29 am by markran »
markran
« Reply #4 on: August 11, 2017, 02:10:03 am »
Just a follow-up post. I uploaded the requested diag file three days ago. I'm stuck and can't figure out how to get GroovyMame to run.
Is there another place I should try to see if I can find some help?
- Mark
Calamity
  • Moderator
  • Last login:September 16, 2026, 03:11:54 am
  • Quote me with care
« Reply #5 on: August 11, 2017, 03:27:34 am »
If your card is based on the 9250 it won't work with modern MAME, you need an specific patch for it. Try this build http://forum.arcadecontrols.com/index.php/topic,154799.0.html
Assuming it's the same issue as this: http://forum.arcadecontrols.com/index.php/topic,154617.msg1621497.html#msg1621497
« Last Edit: August 11, 2017, 03:34:42 am by Calamity »
