Author Topic: Dolphin - driving force gt  (Read 2800 times)
ant2
  • Last login:June 02, 2024, 07:05:47 am
« on: July 31, 2017, 05:05:24 am »
I can't seem to get the steering dialed in on my driving force gt.
I'm using double dash for testing and no matter what rotation degree restriction I set it on, it feels very all or nothing.
Turns just skid about.
My g27 works perfect, but I set that up 6 years ago and I'm not sure if I'm missing something.
The controller is definitely defined as a "wheel "
shaolindrunkard
  • Last login:June 11, 2025, 09:02:25 pm
Re: Dolphin - driving force gt
« Reply #1 on: August 01, 2017, 08:41:41 pm »
I have a lot of experience with this, its the way the game is programmed not the wheel. The way the steering works in double dash is very strange. If you turn around 30 degrees it automatically goes into a skid. I've tried both the wheel and the standard controller settings and the controller setting work better in my opinion. You'll probably have to set the wheel to 180 degrees if that's even possible. You also have to set the deadzone a little high and set the radius so that the wheel reaches just to the edges of the circle if not a bit inside the circle.
Even with the settings as good as I can get them the steering is still not perfect, but at least playable.
Conversely if you set up a wheel with f-zero gx, it works perfectly...
ant2
« Reply #2 on: August 02, 2017, 02:36:59 pm »
Thank you.
Changing the controller configuration from wheel -> controller did the trick.
I tweaked the rotation settings to 115->125 degrees rotation (can't remember what I landed on)
I had the deadzone on around 5 and the radius modified by a tiny amount and it felt good enough.
