Author Topic: Servostik, LEDBlinky, Mame, and Pinballx  (Read 2103 times)
Spotlight Displays
  • Last login:July 26, 2025, 06:16:33 pm
« on: July 17, 2017, 03:23:17 pm »
Hey guys, I recently installed a Servostik. It works great using the Joytray software which you need to use the F4 F8 to switch to ether 4 way or 8 way.
I would like it to switch automatically when the games are selected in Pinballx so I installed LEDBlinky. I was told by the developer of LEDBlinky (Great Guy!) that I needed to have Mame in the address where Pinballx calls on Mame games.
I went into Pinballx settings where you can assign "Other Systems" settings. The current folder is called Arcade. I switched it to Arcade/Mame and put the xml file that was currently residing in the Arcade folder into the new Mame Folder.
If I go into game manager all the Mame games are listed but the wheel art wasn't showing. I went into the media folder and copied all the files into the new Arcade/Mame folder and the wheel art is now present.
The problem is the games will not load when launching Pinballx. So something else needs to be updated and I don't know what that is?
I need to know when you add a game in Pinballx, what files are effected/created?
I'm pretty sure if go and delete the old xml file and add all the games in the new Arcade/Mame folder it would probably work, but that would be a huge job.
If anyone has any ideas I would greatly appreciate it!!!!
Thank you!!!!
Spotlight Displays
Re: Servostik, LEDBlinky, Mame, and Pinballx
« Reply #1 on: July 20, 2017, 03:42:55 pm »
Fixed!!! PinballX does not like / symbol. I changed the path to Arcade_mame and it worked. PinballX doesn't like - Arcade-Mame does not work.
LEDBlinky needs the path for the Mame games to have Mame in the path or I should say name/folder in Pinballx settings for other systems.
The Servostik now changes on its own depending on the game selected on the pinballx front end. So Food Fight switches to 8-way and Pacman switches to 4-way.
It Works Great!!!!!
