Author Topic: Using 1 I-Pac on 2 Computers  (Read 1950 times)
cptdunsal
  • Last login:May 14, 2021, 08:58:14 pm
« on: July 14, 2017, 04:57:18 pm »
Hi. Just joined the group and I have a question already.
I currently have a MAME cabinet that has served me well over the years whit a nice 2 player control panel. The PC is outdated but runs all the games perfectly. Im upgrading to another PC with windows 10 and would like to put newer games on it but not remove the old pc. I would just keep both pcs in the same cabinet. My question is. How can I use the current I-Pac that is already wired to the 40+ buttons on my control board on BOTH pcs. Will I have to unplug it from one and plug into the other when I want to change PCs? Can I keep them use a hub and will the I-Pac just use the PC thats on? I don't want to take the games and put them all on the new PC. I want to use the I-pac  that is already set up on both.
Does anyone know how I can make this work?
Titchgamer
Re: Using 1 I-Pac on 2 Computers
« Reply #1 on: July 14, 2017, 05:39:56 pm »
You could maybe use a USB switcher?
paigeoliver
  • Awesome face!
« Reply #2 on: July 20, 2017, 06:14:55 pm »
You are seeking a very complicated solution to a problem that as far as I can tell doesn't even need to exist. Why do you need both computers in there?
Easier solution. Get a USB stick, something 8-32 GB should be fine for a system that got set up a long time ago. Then copy all your emulation stuff onto the USB stick. Now plug the USB stick and the Ipac into your new computer.
05SRT4
  • Check out my Pow Pow
« Reply #3 on: July 20, 2017, 06:35:35 pm »
Honestly its going to take as much time figuring out a work around vs just moving everything to the new PC.
