Author Topic: (SOLVED) Hyperspin videos do not appear after I've installed groovymame  (Read 6389 times)
Diogo
  • Last login:December 18, 2023, 07:29:04 pm
  • Learn a little every day ....
Hello everyone ... the hyperspin videos do not appear after I installed groovymame, instead they are a completely greenish screen ... what could be wrong? ???
« Last Edit: July 11, 2017, 01:54:45 pm by Diogo »
haynor666
  • Last login:June 12, 2026, 12:46:32 am
  • retro maniac
Re: Hyperspin videos do not appear after I've installed groovymame
« Reply #1 on: July 11, 2017, 01:26:13 am »
Caused by modified ATI driver.
Acpowell
  • Last login:April 05, 2019, 11:18:00 am
« Reply #2 on: July 11, 2017, 01:29:18 am »
You need disable hardware acceleration for flash video.  Just open a browser that supports flash, go to a page with flash on it, right and go to settings.  You should be able to disable it there.  That worked for me a while back with the same issue.
haynor666
  • retro maniac
« Reply #3 on: July 11, 2017, 11:10:08 am »
True but if I remember right You can do this only in firefox.
Acpowell
« Reply #4 on: July 11, 2017, 12:13:32 pm »
Hmm that I am not sure, I cannot remember if I have firefox on my arcade machine.  Either way it is simple to install firefox  ;D
Diogo
« Reply #5 on: July 11, 2017, 01:43:41 pm »
Thank you, I did exactly as you said and it worked now, thank you! :cheers:
Diogo
« Reply #6 on: July 11, 2017, 01:46:55 pm »
Thanks for the guidance, I installed firefox and I followed Acpowell's tip and it worked ... thanks to all of you for the help!
« Last Edit: July 11, 2017, 01:51:41 pm by Diogo »
Acpowell
« Reply #7 on: July 11, 2017, 01:53:16 pm »
Thanks for the guidance, I installed firefox and did as friend Acpowell said and it worked ... thanks to all of you for the help! ;)
Glad it worked.  My friend and I have gone through that process already :)
