Author Topic: can i set pi/retropie to use a certain area of a monitor?  (Read 4835 times)
aldub516
  • Last login:November 29, 2018, 03:32:46 pm
im finishing a mini bartop build.. built with all scraps or extra materials and arcade parts just for fun and to keep budget low. I want to use an old monitor i have that will fit but the monitor screen is too big for the machine. The actual monitor fits in but you cant see the whole screen so i wanted to know if i can set pi to cut out portions of the screen/display on a given part. For instance if i want to cut off 3 inchs off the top, and bottom or whatever.. aspect ratio can be wacky if need be, but yea. Just wanna figure out how to or if i can do this.
05SRT4
  • Check out my Pow Pow
Re: can i set pi/retropie to use a certain area of a monitor?
« Reply #1 on: July 03, 2017, 04:41:30 pm »
Just did a quick google search and found this.
http://elinux.org/RPiconfig#Video_mode_options
Now I have never done this but I am thinking it may have something to do with the Over Scan options.
mahuti
« Reply #2 on: July 05, 2017, 02:41:00 pm »
Yes, it's the overscan options, and yes, you can cut off a LOT using overscan. 3 inches should be doable.
Code: [Select]
disable_overscan=0
overscan_left=24
overscan_right=24
overscan_top=24
overscan_bottom=24
Here's the official Raspberry Pi docs on video config:
https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
Search the page for disable_overscan and you'll see the rest of the options below.
