Author Topic: Monitor position adjustments?  (Read 1857 times)
Foxsec
  • Last login:July 01, 2017, 09:26:10 am
« on: July 01, 2017, 09:05:29 am »
Hi guys. I'm struggling to find a CRT which will fit my cab (21') but I have found plenty of LCD screens which are 12.5'
So my question is, would I be able to put a larger monitor in the cab but use the adjustment settings to pull the picture in some so it fits?
any advise on this would be greatly appreciated
mourix
  • Last login:August 08, 2025, 05:22:39 pm
Re: Monitor position adjustments?
« Reply #1 on: July 12, 2017, 06:51:00 am »
CRT's can usually shrink a lot if you have access to the service menu, but LCD's depend on the brand as you usually only get a fine adjustement.
If you use a PC or raspberri pi as a source, you will be able change it all in software, though.
